Results 1 to 10 of 13
Thread: Air flow meter ??
    North Wales
    Default Air flow meter ??
    Hi all im only gettin approx 50miles to £10 (99.9p a litre). This is combined motorway at max 60mph and around town.
    Im driving very nice to get 50 miles if i put my foot down i onli get approx 40 miles.... AND IVE ONLY GOT A 1.8 :O.
    Some times when i start the car it over revs and cuts out.. im thinking maybe the air flow meter is on tis way out ???
    Any ideas any 1 ?????
    Bristol
    Vehicle : CDTI 150
    What year is the car, can you carry out a paper clip test to see if there are any fault codes stored?
    Could be MAF, could be temp 2 sensor, could be lambda sensor.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    You cant do the paperclip test on Vec C's mate.
    Regular Member Jezzy's Avatar
    S.E
    The brakepedal version of the paperclip test then.
    Regular Member poves's Avatar
    lancashire
    Well I've just replaced the mass air flow sensor on my golf v5 , and it's like a different car.
    No uneven idle anymore , with smooth power delivery , and goes alot better as well.
    If you think about it , the maf sensor is the first point where the ecu and management system electronically controls the running of your car , so if there is the slightest problem there , it will magnify further along the lines , overfuelling and so on.
    So I'd say change it , you have nothing to lose , only make things better hopefully.
    North Wales
    My car is 53 plate.. It is still under warranty (via nissan dealrship) so if the mass air flow sensr is faulty will it store a fault code ??
    What is the paper clip test ????
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by craig-k View Post
    its when you put a paper clip in the dia port and the dash flashes a number of times and gives you the number of the fault
    works a treat on the ol redtop engines
    birmingham
    Engine : 3200
    http://www.topbuzz.co.uk/info/fault_...ault_codes.htm
    look here m8, this is the paper clip test
    North Wales
    dnt fancy doing that... will jst take to Vaux and just tell them it over revs cuts out flat spots etc... If the maf is faulty will it store a fault code ???
    S.E
  1. air flow meter
    By tyler boy in forum Engine & Drivetrain
    Last Post: 17th November 2011, 22:20
  2. air flow meter
    By bulldogblu in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 12:44
  3. air flow meter
    By Morephun in forum Engine & Drivetrain
    Last Post: 13th October 2008, 19:42
