Thread: quick question about diesel filter
    Regular Member signum03's Avatar
    worthing
    Default quick question about diesel filter
    hi changed diesel filter on my y30dt engine, i assume if the main seal was not seated correctly it would leak diesel due to pressure?. i am sure its fine just being paranoid i guess.would there be a obvious leak?
    worthing
    bump
    worthing
    bump
    Newcastle under Lyme
    Wouldnt necessarily leak oil as the oil filter is upright. may get some oil splashed if the gap is severe - no where near as bad as if it was the sump plug washer (upside down). Easiest way to check is completely dry the area with tissue and tehn take it for a drive then recheck. Other than cross threading I cant see the seal being on wrong
    Regular Member poves's Avatar
    lancashire
    LOL ^^ If the seal wasn't seated correctly , air would be drawn in , and you'd notice the running of your car would suffer.
    Quote Originally Posted by poves View Post
    I knew that too lol
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  3. quick 3ltr v6 diesel question...
    By bobby-tupper in forum Engine & Drivetrain
    Last Post: 9th September 2009, 23:24
  4. Quick Air Filter Question
    By tj 666 in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2007, 07:39
