Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: water / methanol injection fitted :)
    Regular Member mat100edt's Avatar
    south coast
    Default water / methanol injection fitted :)
    wish i had discovered this stuff sooner!!!
    i came across a thread on another frum weeks ago about the delights of water/meth injection, i had never heard of it.
    so i did lots of careful research into it .
    i then started looking at kits which range from about £220 to £800
    well i didnt want to pay this so i made my own. cost about £60
    for those who dont no anything about it an are interested just type it in google and you will be flooded with info!
    just thought i would share it with you guys
    south coast
    oh and apparently the results are even better on turbo diesels!!
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    Sounds interesting. Does it only work on forced induction engines or can NA engines benefit too?
    Speaking of benefits, what are you seeing with yours? You can't post about a £60 performance mod without more info, come on mate, don't leave us hanging.
    south coast
    no doesnt have to be forced induction althogh the whole point of it is to cool the air entering the engine which is obviously more effective on forced induction.
    i did read that gains of 10-15bhp have been recorded in n/a staright 4 engines.
    i have set mine up to work on pressure switch (also master switch inside car for disarming whole system) i have had my car remped and my boost is now max 1.3 bar, so i have set the pressure switch to come on at 1 BAR. as it kicks in you can feel the car pull again as if it has just had a nice big gulp of fresh cold air. seems smoother at the top of the gears too.
    i installed it yesterday and went for a drive for about half an hour and gave it a good hammering. pulled over after about 20-30 mins to check everything was all ok and when i toucjhed my boost pipe it was like a ****** fridge.
    well worth the money i reckon!!
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    im really interested in this, but,
    what components did you use?pump, injector, etc. are you going to do a how 2 for it? if not do you have any fotos of the install?
    the kits i have seen are like £150+
    Cambridgeshire
    I have heard about this and was really interested in doing it but when finding out how much to get the kit i gave up.
    How2 on this would be brilliant mate, i have also heard that it could bring some good gains on the CDTI's because diesels hate warm/hot air.
    info info info please
    south coast
    i can take some photo's mate, its easy to do .
    i have a 1.2ltr washer bottle in boot (should have gone bigger) ebay £12 brand new
    i have a 3bar (43psi) fuel pump ebay £15 brane new
    12v fluid solenoid from RS £9 (dont really need this a one way check valve will do)
    a few fittings £10
    injector is from ebayer £8 (its a devils own alcohol injection rated at 7 galons per hour at 100 psi, but im using 43 PSi pump so running about half of that)
    some 8mm hose i already had, wire already had and a switch i already had.
    south coast
    yes i hear 60bhp is possible on a decent diesel engine.
    Regular Member SXi 2.0t's Avatar
    Helsby
    Sounds very interesting there, please keep us informed with updates, as I am tempted to do this myself
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Didn't NUTRON do something like this in the past?
  1. Devils own methanol injection
    By winnie2457 in forum Diesel Engine related
    Last Post: 1st March 2011, 13:26
  2. water methanol injection questions
    Last Post: 21st May 2010, 21:11
  3. Is anyone still using water \ methanol injection?
    By Ziggy in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2009, 15:29
  4. Uprated the Water Methanol injection
    By nutron in forum Tuning
    Last Post: 29th February 2008, 19:48
  5. Aquamist 1S Water/Methanol Injection System
    By spoons in forum Diesel Engine related
    Last Post: 30th December 2007, 04:28
vectra c water meth
