I've fitted the mirror loom and mirror tonight but i was wondering does the loom need activated to be recognised by the ecu via op-com and also is the rain sensor part of the main roof loom or is it an additional loom like the mirror ????
rainsensor is part of the original loom.. if not there you have to replace the loom, rainsensor needs activation.
the mirror should not need activation.
Thanks for the help mate i'll check the original loom to see if it has the plug on it .... I hope it does because getting the roof lining freed is a nightmare
tell me about it i have changed both looms...
I've got the other loom there but fingers crossed i won't need it ...
then i hope you wont need it as if yours you have extra it will be for a facelift that i need
if you got that loom from sri rich it wont fit yours... as your car is facelift and loom is from prefacelift.. (also different rainsensor)
i used the mirror and loom from big rich but ive got a facelift elite loom from a 2008 also.... I'll need to get a differant rain sensor then .... I've also got a spare auto mirror, rain sensor, prefacelift loom now
you will need to use the facelift parts as yours is a 2007.
mirror and mirror loom are the same on all model years.
how much for the loom mate?
