Results 1 to 10 of 16
Thread: Keep getting trouble code: P0400-5A, on SRI CDTI 150
    Birmingham
    Default Keep getting trouble code: P0400-5A, on SRI CDTI 150
    EGR Valve and Boost sensor have been cleaned and all the trouble codes have been reset.
    Now the system keeps dropping the spanner light on the dash with the same code.
    The spanner light turns off after the car is turned off then re-started!
    ANYONE !
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Jezzy's Avatar
    S.E
    Could be that the EGR valve needs replacing rather than cleaning. You probably already know this but P0400 is for EGR malfunction, and P0400-5A is for insufficient flow detected.
    EVERYWHERE
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    my money is on a new valve m8
    EVERYWHERE
    Make sure you read the 'HOW 2' on EGR cleaning before you finally decide to replace though.
    Good threads here.
    http://www.vectra-c.com/forum/showth...t=48513&page=2
    http://www.vectra-c.com/forum/showpo...50&postcount=1
    Birmingham
    I followed that second link on the cleaning.
    Bye bye Vec B
    - Hello Siggy!
    EVERYWHERE
    Quote Originally Posted by Vaux-Man-G View Post
    It looks like you're one of the unlucky ones then mate.
    It might be a good idea to use the 'Fiat' gaskets on your new one though.
    Wales, UK
    How do Fiat gaskets help ?? Is that because they are open and dont have the partition ?
    EVERYWHERE
    Quote Originally Posted by mark_647 View Post
    If you read the other (top) thread above you will see.
    Birmingham
    With the Fiat gasket, as its only got 2 small hole's, would that not just mean more carbon build up on the manifold side?
    Bye bye Vec B
    - Hello Siggy!
  1. P0400-f8 fault code
    By leeeager in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2012, 13:08
  2. p0400-5a fault code
    By swvectra in forum Engine & Drivetrain
    Last Post: 12th July 2011, 06:57
  3. P0400 Fault code help needed PLease.
    By Nick1 in forum Engine & Drivetrain
    Last Post: 20th September 2010, 20:41
  4. Error code p0400, EGR help.
    By Rainbow6six in forum Engine & Drivetrain
    Last Post: 21st July 2010, 10:07
  5. Error code: P0400 - EGR
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 3rd January 2008, 17:20
p0400-5a
p0400-5a vectra
vectra p0400-5a
zafira b p0400-5a
vauxhall zafira fault code p0400-5a
p0400 5a vectra c
p0400 5a opel
zafira error code p04005a
opel fault code p0400-A
