Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: How about solenoid valves!?
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default How about solenoid valves!?
    We now have electrically controlled fuel injection via solenoids, so surely the next step is to replace all the valves with said and get rid of cam shafts and just use a crank angle pickup in conjunction with an rpm sensor to allow an ECU to calculate optimum opening times.
    Does anyone know if any manufactures are working on this?
    Why would anyone want to develop this?? The thermal load that the solenoids would have to take would make this a no-brainer..there is no advantage to running them electronically IMO..
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    Cummins tried it on heavy commercial diesels about 12 years ago, it never got past initial development testing.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Did you work for Cummns Robbie?
    I worked on the QSV91G engines.
    Dec 2005
    Yes used to work in heavy engine development, never worked on gas burners though. Diesel is my passion
    'Norf Yorks.
    Interesting mate. So you were based at Daventry?
    Cummins qualified myself, but only in the gas engines.
    QSV91G is based off the diesel engines anyway. 16 and 18 cylinders as developed closely with Wartsila until they lost love with each other.
    Gas engines are fun, our company operates all the gas engine prototypes in the UK pretty much except Jaguar in Coventry.
    Many a day has been spend overhauling one of them. Good engines. Though with the new projects we are doing we are heading towards Yanbacker (sp).
    Dec 2005
    Some of my projects were
    This one is the N14 Rated from 315bhp & 945lb ft up to 525bhp & 1650lb ft
    This one is the QSK 19 Rated from 525bhp & 1775lb ft to 800bhp & 2275lb ft
    This one is the QST30 Rated from 760bhp & 2470lb ft to 1200bhp & 3750lbft
    All used in heavy truck and plant equipment depending on variants
    'Norf Yorks.
    Ah got ya I work on the industrial genset engines
    'Norf Yorks.
    The QSV91G
    Changed alternators on these a few times now
    Dec 2005
    No I was based up here in the North East when Darlington had it's own engine plant.
    Went on a good few trips to Omaha in the states though.
  1. Solenoid Reset help
    By Badger59 in forum Electrical & ICE (including SatNav)
    Last Post: 5th November 2012, 22:09
  2. Actuator Solenoid
    By chris_gsi23 in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2012, 18:15
  3. Cleaned EGR + Solenoid - now as new
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2012, 20:23
  4. Testing EGR solenoid!!
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 3rd April 2011, 22:19
  5. solenoid vacuum switchover valves
    By andy8966 in forum Engine & Drivetrain
    Last Post: 8th October 2007, 00:41
pigpibut
