Results 1 to 2 of 2
Thread: 2.0 DTI Bleeding Fuel System
    Jun 2007
    Devon
    Default 2.0 DTI Bleeding Fuel System
    I have the Sealey hand priming pump, which I think goes in the return fuel line between the injector pump and tank. Anyone know where i would connect it? The priming tool has quick release fittings on it but I can't see any under the bonnet
    Any ideas?
    New Member dicthebig's Avatar
    Aug 2009
    Bulgaria,Italy
    Vehicle : Vectra C Y20DTH
    Engine : Y20DTH
    Year : 2002
    Mileage : 167000
    I found the right place for that pump is before filter.The same thig must to do my self.3 days out of starting, after changing the leak-off pipes.I also release a litle the injector high presure way - to wait for diesel kome out(exit the air).
    Finali i think the problem for need of bleeding is of hey position way of diesel around the filter.It is half meter up and small portion of air alow to return the fuel back.
    Regards from sunny Bulgaria!
  1. Bleeding the air from the diesel fuel system
    By pete7175 in forum Engine & Drivetrain
    Last Post: 27th July 2016, 07:24
  2. air in fuel system
    Last Post: 14th May 2013, 08:23
  3. Help bleeding the heating system on vectra c 1.8 ls
    By 0114NIGEL0114 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th November 2010, 00:34
  4. De-Pressurise Fuel System?
    By jamesr in forum Engine & Drivetrain
    Last Post: 12th February 2008, 09:02
  5. Fuel System Cleaner
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2007, 15:43
bleeding injectors in a zafira 2.0 A
how to bleed the air out of the diesel on a 2005 signum 2.0 dti without a bleeding kit
how to bleed a 2.0dti vectra
how to bleed diesel 2.0dti
bleed the fuel lines on a vauxhall astra 2011
zafira dti fuel bleeding
vectra 2.0 dti air in diesel
bleed fuel system diesel vauxhall vectra
how to bleed 2.0dti
opel vectra c 2.0 dti fuel system
bleed injector pipes vectra c
how to bleed a vauxhall zafira 2.0 dti fuel
how.to bleed vectra 2.0dti
bleed vauxhall2.2 dti
vectra c dti quick release
how to bleed the fuel system on a vectra c dti
vauxhall vectra ls dti 2.0 how to bleed the fuel
bleeding diesel engine vauxhall vectra
how to bleed diesel pump on vauxhall omega dti
