Thread: Just got back..After limp mode saga..03 2.0dti
    East Midlands
    Default Just got back..After limp mode saga..03 2.0dti
    Been to the IOW on my hols,really enjoyed it,except for the dredded Spanner light on numerous occasions on journey back upto East Mids...came on just as i was getting into Cowes for the ferry...so pulled up switch off ..switch on, alls good for 40 odd miles then back on again...basically all the way home 200 odd miles kept coming on.
    Hope it's not gonna be an expensive jobo..???Anyone got any ideas as where to start....Cheers. Mick
    Nottinghamshire
    Plenty of stuff about the spanner light on the DTi's on the forum. First though you need to get the fault code read as this will point you in the direction of the problem.
    Often on the DTi's it's the boost pressue sensor needing a clean/replacement or holes in the vacuum/air pipes. If this turns out to be your problem, take a look at the good advice on posts like the one below.
    http://www.vectra-c.com/forum/showthread.php?t=75475
    Edinburgh
    Quote Originally Posted by James24 View Post
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Boost sensor a good place to start then check the vacumm pipes for splits and if any have come adrift, thats what happened on mine. HTH
    East Midlands
    Just checked the hoses mentioned..seem ok but strangely enough the bulb check light just came on..hey whats that all about..can't be linked surely.?????
    East Midlands
    Just took the black cover off,and looks like the offending pipe is this one with a spil in it at the top,just phoned the dealer up with the part number off the pipe, which is 24415009 and its not coming up on there system as being the rellevent part.....??Does anyone know the part number if different to the above cheers..trying to order one so i can get it fixed.
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    If its the one on the left as you look at the engine then mine has 55352542 on it HTH
  1. 2.0DTI limp mode.. AGAIN!
    By The_Dutchman in forum Engine & Drivetrain
    Last Post: 20th June 2012, 21:49
  2. 2.0Dti went Bang then into Limp Mode
    By TonyP2020 in forum Engine & Drivetrain
    Last Post: 25th April 2011, 23:14
  3. 2.0DTI Engine Fault - Limp Home Mode Over 3000 RPM
    By coxstevuk1973 in forum Engine & Drivetrain
    Last Post: 4th March 2011, 17:03
  4. limp mode again and again and again stupid 2.0dti
    By barrymanalow87 in forum Diesel Engine related
    Last Post: 8th May 2010, 23:57
  5. limp mode+sort of usual problem 2.0dti
    By bobssignum in forum Engine & Drivetrain
    Last Post: 8th August 2008, 19:04
