Thread: Signum boot catch problem
    Regular Member s1nglef1sh's Avatar
    Fife - Scotland
    Default Signum boot catch problem
    Hi guys
    The exterior boot switch/catch was recently playing up on my Signum. When the car was unlocked the catch wouldn't open the boot. So I carefully removed the cover and rubber seal to reveal the metal plate underneath. It appears that all this plate does is push in a very small switch (size of a match head).
    The only issue I can see is that the metal plate wasn't making the correct contact with the catch and therefore not openeing the boot. The boot opens fine when I press the 'match-head' switch but I'm worried about the eventual damage from water getting in.
    Does anyone know how I can remove the plastic surround inside of the assembly so I can put everything back together?
    Do I need to take the whole boot lid apart? (Hope not!)
    I can post pictures if anyone requires.
    Thanks guys
    Fife - Scotland
    Don't worry guys I've found an old post with a How 2 by Duncan!
    Going to give it a go!
    Regular Member jonny p's Avatar
    wirral
    ive had to fit a new boot release handle for the same problem ... eventually my booy wouldnt open as the handle was worn..... whole job dead easy took bout 20 mins .... good luck m8
    wirral
    the bolts to remove handle are accessable when removed interior boot panel and various other parts as i remember
    Fife - Scotland
    Already all done in half an hour matey!
    Very easy job
    wirral
    good job
  1. boot catch signum
    By roverjay in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2013, 13:53
  2. problem opening Signum boot
    By sigtim in forum Electrical & ICE (including SatNav)
    Last Post: 1st July 2011, 18:03
  3. Signum boot problem
    By keith_johnson1967 in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2009, 18:15
