Thread: possible coolant problem ?
    Regular Member SRI Chris's Avatar
    Jul 2009
    uk
    Default possible coolant problem ?
    hello everybody
    i have just joined up today and i have a quick question if its ok i have a 2008 vectra c sri 1.8 petrol with vvt.
    The question i have is after driving my car so it was hot i got back and i tried to take off the coolant expansion tank cap, it was already at the correct level not down or anything and the whole tank started to fill up with coolant right up to the top.
    If i hadn't screwed the lid back on quickly it would have spilled out all over the place is this normal for a vec c ?.
    I had a 1.8 vectra b before if you did like above all it would do is let out a hiss and then it would be fine, the level would move up a fraction but that was it do i have a possible problem ? as far as i am aware it isnt really over heating.
    It seems to be sticking to around the 90 mark unless in traffic and it goes up to say 95 or on some bits of road it may say go up to 92-93 but then a clear bit of road will go back to around the 90 mark so dont think its over heating ?.
    Any help on this matter would be appreciated so if it isnt normal the car should be covered under the remainder of the vx warrenty so its not a problem cheers.
    from chris
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    My 3.0 and my mother's 2.2DTi are the same. If you're not losing any coolant or having oil mixed in it and vice versa, you're fine
    VIP-Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    All sounds pretty normal, my old B was like yours and the C does the same as yours too. If i take the expansion cap off when engine has been run and hot the expansion tank will fill up like you said. Nothing wrong there, it's just to do with liquid expanding when hot and under pressure etc..
    Laters....
    Bri.
    Today!! The new tomorrow, live the NOW!!
    Glasgow
    Your lucky you did'nt end up with serious burns never lossen the header tank cap when the engine is hot as the system is highly presurised.
    The fluctuation on the temp gauge is normal its just when the fans kick in etc etc. As long as your coolant level sits normal when the engine is COLD lol
    Luton
    Check your antifreeze concentration with a tester - low concentrations have a lower boiling point. You may be forming a steam pocket in the head when you reduce the pressure by releasing the cap. (water boils on Everest at much lower than 100 deg C because of reduced atmospheric pressure)
    Regular Member dj1's Avatar
    leek
    Quote Originally Posted by byebyeitsagsi View Post
    DON'T DO IT!!!!! never undo cap when HOT!!!!!
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I undo the cap when the engine is HOT and I'm still alive. All you have to do is ease the cap slowly and as soon as you hear the hiss step back lol
    Surrey
    If the temperature gauge pointer is between the zones then it's normal operating temperature as per the manual.
    Jul 2009
    uk
    Thanks for the messages guys.
    Glad to hear whats happening is pretty normal as some of yours are doing the same and yes will check the anti freeze content aswell just to make double sure but its only a year old and has never had any work done on the cooling system so it should be ok but i will check anyway as can never be to sure stanger things have happened cheers
    from chris
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Bud
    all modern vehicles use a presurised cooling system ,the reason for the expansion tank is to collect coolant when hot and return it to running level when cold,it's quite normal but as the lads say
    NEVER REMOVE COOLANT CAP WHEN ENGINE IS HOT,you will end up having a ride to your local hospital
  1. coolant problem persists
    By Legion84 in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2013, 12:02
  2. signum 3.0v6 elite coolant problem?
    By carmadcarl in forum Engine & Drivetrain
    Last Post: 25th August 2011, 22:57
  3. Coolant Problem
    By MattHD in forum Engine & Drivetrain
    Last Post: 21st June 2011, 13:22
  4. Coolant Problem
    By ilaing in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2007, 19:58
