Results 1 to 10 of 11
Thread: Engine feels flat
    liverpool
    confused Engine feels flat
    I have recently noticed that my engine seems somewhat dull and unresponsive. It seems slow on the pick up, if this makes sense. I have the 1.9 cdti 150.
    Any suggestions as what the cause of this could be or what I should check / look for on the weekend when I give the car a once over?
    Cheers in advance,
    Andy
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Clean the EGR and boost sensor. That should help you a little. If not, it might be the swirl flaps fault. Not sure how to check that...Someone with a 150 1.9 will surely help you
    liverpool
    Quote Originally Posted by Celes View Post
    Cheers mate, I'll check over the weekend
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Sounds like the EGR, might be stuck open ! i think the egr closes as the rpm
    increases, is your turbo still spooling up ?
    They all suffer a bit of lag though !
    Regular Member barkzz's Avatar
    Take the plastic engine cover off, and look toward the back where the manifold is.
    As you look down there is a metal bar that goes accross with stoppers that match up to some holes. If there are any missing, or completely off centre, or jammed up thats where the problem lies.
    It aint cheap either, bout £800 ntoes to fix
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    EGR - did mine today and it's a lot smoother on lower revs.. will be doing the boost sensor over the weekend.
    Feb 2007
    Tamworth
    Quote Originally Posted by lofty View Post
    Hi, were is the boost sensor ? and how would you clean it, eg: what cleaner to use etc !
    liverpool
    Quote Originally Posted by Kcs View Post
    The turbo is still kicking in, but it seems less erm.. harsh when it does come in. before hand if i would boot it, then the turbo would kick in at 2000 revs and you could feel it kick in. now it still kicks in but not as harshly or at the same revs. sometimes it comes in slightly higher.
    Bsically the turbo seems a little slower to come in.
    Any ideas?
    Jul 2009
    hertforshire
    i thought mine was doing exactly same today. yesterday the turbo felt alot sharper and today it was like is was ''asleep'' car is going in for some work under extended warrenty so i will get them to have a look.....how do you take engine cover off ?
    liverpool
    Quote Originally Posted by Deano.56 View Post
    I aint got a clue yet. I aint had a chance to look over the weekend.
  1. Help please please please Engine flat spot
    By srinav in forum Engine & Drivetrain
    Last Post: 31st July 2011, 18:57
  2. Wheel refurb, flat or not flat B4 lacquer
    By Grumpy1954 in forum Suspension, Wheels & Brakes
    Last Post: 22nd July 2011, 20:11
  3. Engine feels Dull and Unresponsive
    By thompo5 in forum Engine & Drivetrain
    Last Post: 9th January 2011, 14:01
  4. Feels like un-balanced.... but..
    By chewy71 in forum Suspension, Wheels & Brakes
    Last Post: 17th November 2010, 13:43
  5. Feels like a new car!
    By @ndy-e in forum Quick Photo Album
    Last Post: 2nd November 2009, 01:40
cdti 150 feels flat
