Thread: headlights alignment?
    Jul 2009
    letchworth
    Default headlights alignment?
    Hello,
    I have just replaced the standard H7s with the Philips X-Treme Power +80%. The trouble is that the dipped beam now is a lot worse than before!! It is so dark in front of me that I can't even exceed 40 miles on a dark country road without using the main beam.
    What went wrong?
    Can anybody help please!!!
    Panos
    Full Member Big Sig's Avatar
    Make sure they are seated correctly in the holder/clip in the light unit. I have managed to put the bulb in on an angle before that effects the beam direction.
    Jul 2009
    letchworth
    OK, but how can I be sure they are seated correctly?
    Undo the metal clip that holds the bulb in, give the buld a twist and it should "lock" in so it won't turn. If it turns then its not seated correctly.
    Hope thats clear
    Jul 2009
    letchworth
    Many thanks Big Sig,
    I will do tomorrow morning and get back to you!
    Panos
    Newcastle under Lyme
    mine were exactly the same and the HID bulbs were seated correctly. I had to adjust the beam height with an allen key. If you want to do it properly either pay or follow ste's advise and equation here -
    http://www.vectra-c.com/forum/showthread.php?t=82321
    I never got round to doing it this way and did it through guess work and taking it for a drive along a country lane a few times til I was happy. I think they are too high at the moment but never been flashed.
    No idea why mine dropped but it was scary driving back from Manc airport at 2am. I had to put main beam on.
    Jul 2009
    letchworth
    Many thanks JSYSH466Y,
    indeed, I ve checked them this morning and they are seated correctly. Thankfully the day is long so I have a few more days to either do it myself or go to a VX dealer!
    many thanks for the link,
    cheers
    Panos
  1. 4 wheel alignment again.!!!!!!!
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2012, 19:37
  2. wheel alignment
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 10:57
  3. Trying to Get Alignment Done
    By Jezzy in forum General Chat
    Last Post: 3rd March 2010, 12:49
  4. xenon headlights alignment
    By lakis123 in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2009, 08:50
  5. Wheel alignment
    By silverhairedracer in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2007, 13:33
