Thread: Radiator drain plug - 1/4 turn ?
    Full Member
    Luton
    confused Radiator drain plug - 1/4 turn ?
    Hi - this should be very obvious I know. But the plug on my 55 reg 2.2 petrol seems to turn through 90 degrees, but no coolant is coming out of the `spout'.
    Is it 1/4 turn, and/or does it pull out ? Or just unscrew ?
    Plug is about 13-15 mm diameter, with a raised `rib' across the centre of it.
    Don't want to wreck the rad !
    Full Member spennny's Avatar
    Blantyre
    Looking at the car its down the LHS, you have to twist it 1/4 turn anti clock wise and pull it out
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by spennny View Post
    Yup did you get it out mate?
    Blantyre
    Quote Originally Posted by Sean-2.2Direct View Post
    Yep, but like the OP i thought it pulled right out, only 40 mins passed before i realised it didnt, pull and twist
    Apr 2008
    Liverpool
    Sorry mate I thought I did mention that Opps
    Full Member
    Luton
    Well - my plug turned fairly easily through 1/4 turn, but despite a reasonable yank with a pair of pliers, refused to pull out. Is there an `O' ring somewhere ? Anyhow gave up and popped the lower hose from the radiator, which came off quite easily. (I used a ground down pair of cheapo water pump pliers from B+Q for the spring type hose clip)
    Thanks anyway. (and much prefer the old Omega type drain plug)
  1. f40 drain plug access
    By justin32 in forum Engine & Drivetrain
    Last Post: 26th November 2011, 15:10
  2. Radiator drain plug question
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2011, 20:41
  3. Gearbox oil drain plug
    By big nath in forum Engine & Drivetrain
    Last Post: 15th February 2011, 18:13
  4. Radiator leaking from drain tap
    By fuzzbomUK in forum Engine & Drivetrain
    Last Post: 30th March 2009, 19:53
  5. oil drain plug ?
    By dmoffat in forum Engine & Drivetrain
    Last Post: 17th June 2008, 10:27
vectra c radiator drain plug
drain plug on insignia radiator
radiator drain plug vectra c
vectra c radiator flushvectra c coolant drainvectra c 2.2 drain coolantvectra c water overflowing when bleeding coolantvectra c coolant flushhow do I know radiator drain plugvectra c coolant drain plughow drain radiator vectra cvauxhall insignia drain plug on radiator drain coolant vectra c 2.2corsa c radiato drain plug r o ringvauxhall vectra radiator drain plug
