Thread: light control unit
    Regular Member shaun260589's Avatar
    Jun 2009
    Newcastle
    Default light control unit
    just wondering if any of you guys had heard of this
    got the vec last week and few days later my dad was swapping cards round on the drive and i told him the drivers side brake light was out,
    anyway we gets the holder out and theres no bulb in, so get a bulb put it in the holder (without ignition or any lights switched on) and it pulses and if you switch sidelights on the brake bulb stays lit as if brakes are pressed, and this is only on driver side
    our auto electrician we use reckons its the light control unit at the back and will be a 400 quid job + tech2 time
    weve taken car back indipendant dealer we got it from and looks like hes trying to get out of doing it on the 90 day warrenty but weve been advised by cit advise we can get money back in small claims,
    hes getting his auto electricion to check it out on monday to see what the problem says
    any coments advise would be welcome
    cheers
    Mar 2007
    North East
    There was no bulb failure warning lamp on the dash ??
    Sounds like the car has an electrical fault and yes it could be expensive. The fact that the dealer knowingly sold a vehicle (you would assume that they would have made this basic check) without working brake lights is a bit suspect to say the least.
    london
    Had a problem like this on a jaguar s-type, turned out to be a blown fuse on another light circuit caused by someone fitting the wrong bulbs.
    it is worth just checking all the fuses and bulbs.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    you need to get checked on tech 2 with past experience sounds like its the REC in the boot fuse box on left side about 300 pound job ..
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Am I right in thinking that there is a back-up circuit on the Vec c that will illuminate a brake light bulb, if the tail light for that side fails...
    Try checking the tail light on that side...
    Jun 2009
    Newcastle
    the sidelight didnt come on as a back up brake , and no bulb warning lights , our auto electrician also thinks the REC in the boot fuse box ,
    Jun 2009
    Newcastle
    just realised u said check the sidelight , yep thats fine , as soon as we put a bulb in the right place it started pulsing (no lights or ignition on) then when we switched the sidelights on it came on bright as if pressing brake pedal and this is only on the drivers side
  1. For Sale: AFL Control Unit
    By plasma in forum Parts for sale
    Last Post: 11th October 2012, 16:50
  2. ids control unit
    By aberg in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2012, 20:39
  3. AFL Control unit
    By kosen in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 18:34
  4. body control unit
    By jstal40024 in forum Bodywork & Interior
    Last Post: 13th September 2009, 22:05
