Thread: Puncturesafe
    Regular Member cabbage's Avatar
    Bristol
    Default Puncturesafe
    Puncturesafe is liquid that stays permanently in the tyre and seals any puncture that happens. Apparently Royal Mail use it on their vehicles.
    Anybody used this product? Is it any good?
    What happens when you pump up the tyre? - Does it seal the valve so you can't get any air in?
    Does it stop blow outs, like when the end of a broken spring fouls the tyre?
    Full Member Big Sig's Avatar
    It also means the tyre cannot be repaired if you wanted it to be in the case of a nail in it etc. Also makes a massive mess of the rim and tyre fitters hate it, they may even charge you for cleaning it off before fitting a new tyre.
    Surrey
    The girlfriends car doesn't come with a spare tyre but 2 cans. There is room for a biscuit wheel.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Is this the one which means you dont have to replace the tyre?
    Im also lead to believe it cant be used on low profile tyres.
    I just read their FAQ and the tyres can be repaired afterwards, its not too clear on low profile tyres as it says to contact them.
