Results 1 to 10 of 14
Thread: rev counter/speedo/temp gauge/fuel gauge stopped working
    haworth
    Default rev counter/speedo/temp gauge/fuel gauge stopped working
    As above they were all working fine then both rev counter & speedo dropped to zero, then went back to reading correct for about 30 secs then stopped completely, all other electrics still worked ok, i drove to the services on the M60 switched of the motor restarted it and hey presto all working ok, did a further 140 miles no problems, any ideas please?
    ps. the idicators worked ok but not the lights in the instrument cluster.
    cheers, keith
    haworth
    sorted,
    I spoke to a auto lecky and he said to remove and clean fuse 17 from the fuse block at the side of the glove box and also remove the block connector on the abs system situated on the n/s inner wing for 5/10 mins {its by the battery}, done it and all seems well. keith
    Regular Member jonny p's Avatar
    wirral
    also happened to me ...an vauxhall sadi to disconnect battery for 10 mins then reconnect to reset everything..... hey presto ..... workin guages
    Regular Member garvey's Avatar
    Co Durham
    sounds abs plug to me
    Doncaster
    Smile
    this has JUST happened to me too.
    RAC disconnected battery for 10 mins and all came back ok. Sunroof didn't work at all for a while but thats come back on its own now! Also windows would only go down in stages - but thats back!!!!
    RAC said they checked all fuses and if the battery fix did not work, then press the speedo ect slightly (could be loose connection) - or to remove a fuse (don't know which one - could be 17 as above) leave out for 3 mins and plug it back in.
    Wierd !!!
    Could also be a sign of a dodgy CIM.
    Regular Member gromit's Avatar
    Cumbernauld
    AAAAAAAAAAAAARRRRGHHH!!!!!!!! Not the dreaded C.I.M!!!!
    Doncaster
    I'd guess I'd have to wait for it to happen again before I go to the dealer (its under warranty) with regards to dodgy CIM???
    Quote Originally Posted by gromit View Post
    Bedfordshire
    Must be the week for this. Driving to work this morning in my Siggy 2.2 Direct, I suddenly get an illuminated symbol of a steering wheel and three dashes on the multi-display, speedo drops to nothing, temp and fuel gauges too, rev counter still working. Then alternator warning light becomes lit, ABS and traction control light on too. I stop, restart the engine and it clears. 2nd helping a bit further down the road, recovered on its own but TC light still on.
    On the way home, I got the same symptoms, then wildly fluctuating working/not working dials, including rev counter this time, then car/spanner symbol and ABS and TC lights on. Drove the few miles home, plugged on U480 reader, no codes shown even though spanner light on.
    I shall see about this fuse 17 trick, but maybe a call into my friendly garage with Tech 2 would make sense.
  1. fuel gauge stopped working - any idea's
    By Top banana in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2013, 09:48
  2. fuel and temp gauge not working
    By hovis007 in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 19:35
  3. Boost gauge stopped working...
    By spoons in forum Petrol Engine related
    Last Post: 9th July 2011, 14:41
  4. Speedo and rev counter stopped working ??
    By Knuckle in forum Vectra C / Signum Troubleshooting
    Last Post: 11th June 2011, 16:59
  5. Engine temp gauge not working ???
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 21:36
vectra c battery light and rev counter jumping
vauxhall speedo petrol guage temp gauge not working
vauxhall insignia rev counter and speedo not working
vectra c gauges stop working abs
Petrol gauge heat gauge speedo meter ref counter not working
vectra c speedo fuek guage and rev counter not working
vauxhall meriva speedometer petrol gauge not working
