Thread: springs for a GSi
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Default springs for a GSi
    Hi,
    Could someone confirm the best type of springs for a GSi. I don't want to change the drop, I want to keep it standard.
    I need to replace the fronts, just wondering if there are any saving buy a full back/front kit.
    Would prefer not to go down the vaux route, the aftermarket shocks seem much better.
    Regular Member Jezzy's Avatar
    S.E
    Problem is that the majority of quality after-market springs are aimed at those who want a lower ride; finding springs of the original height, other than no-brand ebay stuff, can be quite hard.
    Jul 2006
    greenock
    As far as I have found out something like a set (x 4) of Eibachs (from the chaps in the link below) are around £160. That is a drop of 30mm, not sure what drop the standards are.
    I also gather there are different sets for different axel weights 1060kg and 1130kg. Need to check the car when I get home.
    http://www.europerformance.co.uk/
    S.E
    The SRi is 15mm lower than a standard Vec, and I think the GSi is the same.
    Jul 2006
    greenock
    Oh - thanks Jezzy, 30mm is a bit different to 15mm.
    Jul 2006
    greenock
    could someone confirm that it is a 15mm is the drop for a GSi, thanks
    Regular Member kns's Avatar
    Northampton
    As above so if you but a set of Eibachs 30mm drop it will drop yours by a further 15mm not 30mm and they look sweet as I have had mine done
    Jul 2006
    greenock
    Quote Originally Posted by kns View Post
    Thanks kns, I was going tio try and keep it relatively standard.
    When I fessed up about the s/s exh it added a fair bit to the insurance premium (direct line). The site recomended insurance company may be more understanding but I've still got a bit of time to run on the existing policy. Cheers
    I am tempted though
    Nov 2005
    Edinburgh
    I had to have both front struts replaced on my GSi last year at Mot time. It had a broken front spring and the springs themselves were not available as separate parts so I had to shell out for the whole assembly.
    No aftermarket springs were available at the time and like you I wanted to keep the car standard rather than lower the height. Things may have changed now, but I suspect you may be stuck with Vx parts if you want to keep it standard.
    Jul 2006
    greenock
    Quote Originally Posted by D18 View Post
    Hi D18, managed to get a new set of springs from Vaux (sad bit is they were the same price as the full lowering kit £160). The garage also replaced one end of the steering rack which had some play in it (common vectra problem apparently).
    Seem to have spent a fortune on the car recently, and none of it bling
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
