Results 1 to 10 of 21
Thread: Airbag Light due to seat occupancy detection
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    Default Airbag Light due to seat occupancy detection
    I have recently changed my interior to leather from a vectra elite. I did all the right things as to not set my airbag light come on...but it did anyway. Now I have an op-com reader/reseter and it resets the light but comes back within a few seconds with a fault with the S.O.D. ( seat occupancy detection ) it says p0099. I think these seats may have seat occupancy detection fitted but was wondering if there was a simple way to either disconnect it or bypass it using either op-com or tech2. any help welcome as its getting on my nerves now.
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    twist the wire together shorts them out that will turn it off not ideal but will work mate
    which wires?...all the wires I see are pluged in to the harness
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    is ther not two under the seat pluged in mate
    Full Member Big Sig's Avatar
    Quote Originally Posted by paulvectrac View Post
    careful as there maybe an airbag connection there too. The S.O.D - i like it - can be deactivated on tech 2
    [Ex]Admin Duncan's Avatar
    Priceless advice when we're talking about connections that could involve air bags/pre-tensioners!
    As BS said, you should be able to disable the Seat Occupancy if the light keeps coming on - although if the new seats have the SO feature but the car doesn't then I would have thought it would simply have not done anything - if you see what I mean.
    yes there are 2 pluged in...1 small yellow and 1 big black plug. same as the seats i took out
    Regular Member blue estate's Avatar
    oh well.. I tried..
    I have exactly the same issue... code B0975 went to dealers... answer 'dunno mate' helpful NOT
    So i too and stuck with the light on
    right...went to the dealers today with my problem and said maybe tech2 could solve it. he quoted £80 an hour. so instead I went around the back to the garage department and got the young lad to kindly come and take a look free of charge. he plugged the machine in and it said B0099-00 mismatch configuration (SOD) seat occupancy detection. I already knew this and asked him to reset it if possible and he told me the ECU was locked and could not be re-programed and the only other alternative was to buy a new ECU and have it programed again. Now all this because of seat occupancy detection. Now i'm thinking could someone be kind enough to take a picture of their plug on an LS under the seat and see if maybe I have an extra wire in there that I could remove so it no longer looks for occupants.
    anyone...please
  1. seat occupancy sensor
    By cerbrious in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2016, 01:11
  2. Airbag light on after leather seat upgrade.
    By Ian-Highlander in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 22:11
  3. seat belt light and seat occupancy recognition
    By xc600 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2010, 20:26
  4. Seat Occupancy recognition
    By dmck1 in forum Bodywork & Interior
    Last Post: 27th June 2009, 14:50
  5. Seat Occupancy Recognition
    By rich_t4 in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:37
vauxhall c vectra seat occupancy sensor
