Results 1 to 10 of 11
Thread: Vectra window
    edinburgh
    Default Vectra window
    Hi any information or links to threads to do with the driver window on a 58 Vectra hatch found to be down in the morning, I'm sure all the windows were up when I left the car but it was a hot day.
    Thanks fhfh
    Mileage : 000
    It has been mentioned on here quite a lot in the past. Have you tried the "search" button to find any "information". If I remember corectly, someone said that if you close the window and press the "close" button again, the problem should not happen again. I don,t know how true this is but might be worth giving it a try.
    May 2006
    scotland
    Happens to mine as well. Only sometimes when I lock or unlock the doors, the window/s sometimes go down by a couple of inches. I put it down to clashes on the CANBUS. Has done this a handfull of times in the 3.5 years of ownership. The other cause could be if your keyfob is in your trouser pocket when in the house and the car is outside nearby and if the keyfob was pressed by accident in a combination that would lower the windows (you can do this by a combination press of the keyfob).
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by wickedwillie View Post
    You can open your windows with the key fob then? I know how to shut them with the key in the lock, but not open them? Anyone know how?
    Mileage : 000
    Quote Originally Posted by si_hoss View Post
    Unless your motor is different to mine. If I press and hold the open button on my key the windows will open if they are closed.
    Regular Member barkzz's Avatar
    Could be a battery going flat in your keyfob. Did this on mine, was fine once i replaced it, and resynced with the ignition
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Yep you can open and close using the key fob
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    mine won't open using the keyfob but will close using it
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    on mine it open & close's the windows fine
    Blantyre
    Hold Unlock - Opens Windows
    Hold Lock - Closes Windown
    Simplzzzzzzzzzzzzzz
  1. vectra window blinds
    By the fisherman in forum General Chat
    Last Post: 23rd July 2010, 17:25
  2. vectra window tinting
    By progav in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2009, 23:05
  3. window changed on me vectra
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2007, 22:00
  4. vectra-c window stickers?
    By gizmo10119 in forum General Chat
    Last Post: 17th April 2007, 20:59
  5. window fitters on (vectra-c.com) :) ?
    By 2ltrT in forum General Chat
    Last Post: 10th January 2006, 23:25
