Thread: Dual mass flywheel now changed, some piccys
    preston
    Default Dual mass flywheel now changed, some piccys
    Car was rattling more and more when clutch pedal was being pressed although no rattles at top of travel or at bottom, decided it must be the dmf and it was. Changed it monday, took about 6 hours but was going for it. When investigating what goes wrong with them, it appears to be the axial movement that gets worse from what I could see. The damping movement seemed fine, suggesting lots of clutch operation is the cause of premature failure, can't see why the suggestion of pressing the clutch when starting would reduce wear as the ring gear is attached to the flywheel part that is directly bolted to the crank. Anyhow all is well now and no rattling, happy days.
    Good man and not a job I'd have fancied doing on axle stands (for the access) so even more kudos! lol
    Regular Member brad69bj's Avatar
    Jun 2009
    Leeds
    You`ve done well in 6 hours mate! I do mine the same way, in the drive on axle stands. Did you have fun getting to the starter bolts? or did you take egr valve off? lol. They arnt easy to do on yer own are they?
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Wow well done mate you have done a great job there
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    im doin mine in the next few weeks m8,
    well done m8
    preston
    Didn't remove egr valve to get at starter bolts, just undid the bolts and left starter in situ, ensure you make a note of which bolts come out of the engine to gearbox as one around the back has a fine thread, i tried to refit a coarse threaded bolt back in and damaged a couple of threads obviously. When battery box is out there's quite alot of room to gain access to stuff, Flywheel is heavy and the bolts are mega tight, think its a T60 torx you need and a large bar. there's an oil drain plug to drain oil which is handy. No level plug on refilling though, just put the right amount in which in my case was 3.5 litres of automatic transmission fluid for the F40 6 speed. Drivers side drive shaft does not have a circlip holding it in to the gearbox as its held in by by intermediat shaft bearing, just undo this, lift it of the dowels and tap it outwards to draw the shaft out. when I took the flywheel off there was a disintegrated plastic ring in the centre of the flywheel which I suspect is the cause of failure.
    preston
    also ensure when lifting subframe into position that radiator lower mounts go into their grommets in the subframe itself, any misalignment and you'll break the mounts
  1. Dual mass flywheel???
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 12th July 2012, 07:26
  2. Anyone ever changed there Dual Mass Flywheel
    By Gavin2.6 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2010, 20:11
  3. dual mass flywheel...again
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2009, 14:19
  4. Dual mass flywheel
    By 900ss in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 24th January 2009, 17:47
  5. Dual mass flywheel ?
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2007, 20:59
