Thread: V-Grille removal
    Full Member gibbon7000's Avatar
    lincs
    Default V-Grille removal
    Thinking of colour coding my V-grille this week. just a couple of questions really
    1. Are they easy to remove without breaking anything. Can anyone give me tips.
    2. How do I remove the griffin badge, as dont want that colour coded?
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Full Member spennny's Avatar
    Blantyre
    Easiest way is to remove the bumper, then loosen the catches on the back, along the V
    The badge comes out easier once you remove the V, if your down GU14 way, gimme a shout i can help
    Regular Member nigec's Avatar
    barnsley
    These are just the questions that ill need answering soon as this is my next mod, im wanting mine black, whats your colour ? Is it an easy job painting/spraying them as ive never attempted anything like this, what paints and laquer will i need ? help appreciated cheers.
    lincs
    Quote Originally Posted by nigec View Post
    My colour is ultra blue. TBH honest spraying is easy. Key the chrome effect with some 800 grit wed/dry paper. Spray with some primer, rub primer down with 1200 grit wet/dry paper then spray 3 coats of paint, leave to dry, rub down again with 1200 paper and then spray the lacquer on, you'll need 3-5 coats of the lacquer. To start with, just spray the lacquer on to get some coats, leave to dry, gently rub down again with 1200 then when your ready to do the final coat, give a good amount of lacquer, spray evenly and you wont get runs, but it needs to look wet for the perfect finish.
    you can get a paint/lacquer set from the dealers for about £12 but the lacquers crap IMO get some DU-POL from ebay or halfords. HTH
    barnsley
    cheers for that, nice one.
  1. Facelift v grille removal
    By Hyperhart in forum Bodywork & Interior
    Last Post: 6th May 2012, 11:14
  2. Help! Top Grille Removal
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2011, 22:55
  3. removal of upper & lower grille
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2010, 02:09
  4. v grille removal
    By rob888 in forum Bodywork & Interior
    Last Post: 4th November 2007, 11:05
