Thread: hand brake adjustment.
    Regular Member buffallobill's Avatar
    Jul 2009
    barnoldswick
    Default hand brake adjustment.
    hi guys, newbie here, found this forum by searching it looks a brill site.
    i wonder if any member could give me some advice on my car vectra life 1.8 petrol on a 07 plate, the hand brake is at the top of its travel, and needs adjusting, i took the, off side rear wheel off , but there seems to be no adjustment ratchet looking through the extra hole in the small brake drum attached to the disc, there is a lever mecahnism that is attached to the caliper which has the hand brake cable on it ,
    i have looked at back of hand brake drivers side where there is a small triangular plastic cover which i removed but there is no sign of any cable or adjustment there, i am totaly in the dark now, any advice would be rally appreciated thank you bill.
    i hope i have put this post in the right place apologies if i am wrong.
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    welcome aboard m8,
    Has your car had the recall work done on the handbrake m8? If not get her booked in to the nearest vauxhall dealership, they can adjust everything for you there and will be done free of charge
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Welcome mate, the handbrake works on the calliper on the vec c buddy and its self adjusting. Is there plenty of meat left on the rear pads? Failing that it could be a stretched brake cable.
    Nottinghamshire
    The handbrake is auto-adjusting so it must be something other than that - check the pads and discs are OK and then take it from there.
    Jul 2009
    barnoldswick
    thank you guys for a quick reply,and warm welcome. will the recall to mod the hand brake be stamped up in the service book, i cant see any info in it. i will definateley be going to veccy dealers and get them to check to see if mod as been done and to rectify the hand brake problem, what was the mod for on the brakes.?
    Nottinghamshire
    Quote Originally Posted by buffallobill View Post
    There should be a stamped piece of paper for the handbrake recall - it's not in the service book. Your dealer or VX customer services should be able to tell you if your car has been done as the dealers sent details of which cars they had done back to VX.
    The recall was to fit a stronger spring to the handbrake release button so that it was less likely to slip out of the ratchet causing the handbrake to be released and the car to roll away. I'm not sure if/when VX started fitting this at the factory - again, the dealer should know.
    Jul 2009
    barnoldswick
    thanks peeps. on using the info you gave me, i have just returned from vauxhall dealers who assure me my reg no /chassis no. is not on recall. so i have booked it in for a service and for hand brake to be adjusted with new pads if neccessary. thank you for all your help on this subject. cheers bill.
  1. hand brake?
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 21:59
  2. Hand Brake Adjustment
    By Eminox in forum Engine & Drivetrain
    Last Post: 10th June 2010, 17:06
  3. Hand Brake Adjustment
    By scottymf in forum Suspension, Wheels & Brakes
    Last Post: 29th September 2008, 10:01
  4. hand brake
    By JATBOY in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2006, 07:32
  5. hand brake
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 18th June 2006, 11:36
opel vectra c handbrake adjustment
how to adjust handbrake on vectra
vauxhall vectra c handbrake adjustmenthandbrake adjustment vectra chow to tighten handbrake on 2005 vectra www.vectra-c.comvectra c handrake not working evenlyvectra c 57 plate handbrake adjustmenthow to fit vectra c handbrake cablevectra c handbrake problemvectra c handbrake adjusterhow to fit vectra c auto adjuster handbrakevectra c 2005 handbrake adjustmenthow to adjust handbrake on vauxhall vectra 2007vectra c handbrake adjuster www.vectra-c.comhow to adjust handbrake on 57plate vectravectra c hand brake adjustment problemadjust handbrake vectra crear disc handbrake adjusting vectra ccorsa c handbrake adjustment2007 vectra c handbrake adjustmentbrake cable vectra c 1.8 petrolhow to adjust handbrake on vectra c
