Page 1 of 9 123 ... LastLast
Results 1 to 10 of 82
Thread: 3.0 cdti black smoke on acceleration
    France
    Default 3.0 cdti black smoke on acceleration
    I have a problem with clouds of black smoke under acceleration. There doesn't seem to be any loss of power. Car is 2003 vectra C auto estate, 98k miles. 3k miles ago car was serviced by dealer, cam belt and rollers changed as well as brake fluid/gear oil. I have tried redex diesel in the fuel but no improvement. Could this be injectors, EGR, split intercooler hose?
    Cambridgeshire
    Try cleaning the EGR valve mate. That might sort your problems out a bit.
    However, remember that you are driving a diesel and they do like to let other road users know this by kicking out a lump of soot every now and again lol
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by littlejohn View Post
    Hi mate does yours have a DPF ?
    France
    Thanks. Is the EGR hard to get at on the v6?
    I had some black smoke 30k before but nowhere near as bad and a software update seemed to improve it though I can't be sure. Also oil level light came on after 2 hours on motorway 1k after last service. Checked level and it was a little above max. Restarted after 15 mins and light has remained off ever since.
    France
    Sorry Sean, I don't know what a DPF is. Car is Opel LHD.
    Apr 2008
    Liverpool
    Sorry mate Diesel Particulate Filter
    Cambridgeshire
    All the CDTI's are running DPF's mate
    France
    Thanks, Sean. Don't know the answer to that. At last service dealer replaced 3 filter elements, which I assume are diesel, oil and air, and 1 particle filter but that may be pollen filter?
    Cambridgeshire
    Quote Originally Posted by parsco View Post
    Ignore that last statement of mine got it wrong....still not sure which models have the DPF's but apparently mine doesn't have one.
    The DPF is not as simple to change as an oil filter, apparently it's quite expensive
    Regular Member spatch's Avatar
    Aug 2007
    Kent
    As far as I remember only the Euro 4 facelifts run DPf's. The earlier Euro 3's do not.
  1. 150 cdti LOSS OF POWER AND BLACK SMOKE HELP
    By STRETCH2009. in forum Engine & Drivetrain
    Last Post: 4th September 2012, 14:19
  2. thick black smoke cdti.
    By frasedeb in forum Engine & Drivetrain
    Last Post: 16th May 2012, 20:04
  3. 3.0 v6 cdti black smoke
    By joebull90 in forum Diesel Engine related
    Last Post: 15th May 2011, 15:25
  4. 3.0 CDTi I thrashed it and the black smoke went!
    By littlejohn in forum Engine & Drivetrain
    Last Post: 30th September 2009, 16:50
  5. 1.9 cdti (150) Black smoke
    By ste_goffy in forum Engine & Drivetrain
    Last Post: 18th July 2009, 16:37
vectra black smoke when accelerating
Vauxhall signum 3.0 v6 cdti black smoke hissing noise loss of power under load
vectra 22 black smoke no power
vauxhall vectra loss of power when accelerating
why is my 2.0 cdti vectra black smoking
vectra c 3.0 cdti black smoke
vectra c cdti black smoke when accelerating
3.0 v6 signum black smoke acceleration running lumpy tick over
Vauxhall diesel smoke on acceleration 3.0 dti
vauxhall 1.9 cdti black smoke
