Thread: difficult to start in the morning
    durham
    Default difficult to start in the morning
    hi yet another problem with my vectra 2.0 dti 52 plate. Car starts first turn of the key in the morning, then dies after about 10 seconds. when you try and restart it take about a minute to minute and a half of constant cranking to get the engine to start it sounds fuel related as if there was enough fuel to start it left in the filter or where ever then it has to pumped back from the tank. but i,m not a mechanic so not sure. car runs and starts fine all day. it only happens overnight. cheers for any ideas
    Nottinghamshire
    Sounds like fuel could be draining back towards the fuel tank after it has been left standing fora while. You cars starts on the fuel that is in the pump then stops when this runs out and you have to crank it to suck some fuel back through. These cars have no one-way valve to stop this happening. Also bear in mind that the DTi fuel pump is succeptible to damage if cranked a lot without any fuel in it.
    Can you leave the car facing nose-down overnight to see if this helps? It will stop the fuel heading back to the tank due to gravity.
    If this does help or if you can't do it, check your fuel leak-off pipes and T-pieces - these can be found easily at the front of the engine if you remove the plastic cover - there is 1 for each cylinder and one going into the fuel pump.
    If these are split or cracked, they let air in and so allow the fuel to run back towards the tank. Also check the various joins in the fuel pipes that run around the bonnet are OK and that the top of the fuel filter is screwed on properly.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    when you start it turn the key twice and let the fuel pump work give it 10 seconds then try start it hope it helps mate
    Retford
    Be careful because i was had a 2.0DI and exactly the same problem - i ran for at least a week turning over in the mornings, before the garage finally fixed it (i was told by a friend to check the fuel filter head which had gone pourous)
    The fuel pump failed within a few days of having the problem fixed and i had to scrap the car
    durham
    cheers will book into garage these fuel pumps seem a pain in the a**e
    Nottinghamshire
    Yes, the pumps can cause problems on the DTi's. Also - unlike the newer CDTi engines - there's also no electric fuel pump in the tank which makes things worse - the high pressure pump has to draw the diesel right from the tank, and priming after a fuel filter change can be tricky.
    durham
    just to let you guys know if you have a similar problem it was faulty fuel filter seals. i also spoke to a technician from vauxhall who was very knowledgeable. he claims that the fuel pump would not be damaged starting the car in the morning. would only burn out the starter motor. and a lot of people end up scrapping their car or changing fuel pump. when there is actually nothing wrong with it, just being wrongly diagnosed.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi bud
    as james says it's most likley fuel leak off pipes,but check filter seals
  1. Vectra 2.0 DTi difficult to start when warm
    By C470 in forum Engine & Drivetrain
    Last Post: 11th July 2012, 16:35
  2. Vectra 2.0 Dti Difficult To Start
    By dan9895 in forum Engine & Drivetrain
    Last Post: 18th April 2012, 16:30
  3. CDTI 120 difficult to start
    By matt_harw in forum Engine & Drivetrain
    Last Post: 14th November 2011, 21:48
  4. sri 120cdti difficult to start in morning
    By Turbomanrony in forum Engine & Drivetrain
    Last Post: 1st August 2011, 05:27
  5. 1.9 cdti 120 difficult to start and low power under 1500 revs
    By johninthetoon in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2010, 07:46
