Results 1 to 10 of 11
Thread: ARB Bush size
    Cambridgeshire
    Default ARB Bush size
    Hi guys, I've been looking through the search threads and can't find my answer.
    I know I would find the size I need if i jack the car up and take the wheel off etc... but haven't got the time. Has anyone fitted bushes recently to a 1.9 CDTI SRI and remember the size they went for? Will 18mm's fit as I've heard that if the standard was 19mm it could be better to go for the 18mm's if you have lowered suspension?
    Sunny Dartmoor
    Iirc you need 18mm as you said,the 19mm's were originally fitted to non lowered cars.........
    Cambridgeshire
    Top man
    Just wanted some reassurance looks like i'll be under the motor again tonight
    Regular Member dominic32's Avatar
    Oct 2007
    whitstable
    Quote Originally Posted by parsco View Post
    Top man
    do you not have a bed ???????????
    sorry have fun with your bush
    Cambridgeshire
    maybe I should have said this evening lol
    Regular Member denzilbud's Avatar
    cambridge
    hi mate i was given 19mm for my vec sri(2.2)from vauxhall and was told that the 19mm ones are for the lower standard suspension ie sri
    Cambridgeshire
    Quote Originally Posted by denzilbud View Post
    You are correct mate. But mine is lowered even more on Eibachs. (about 15mm) So i'll give it some more support and got for a tighter fit
    cambridge
    how easy were the rear arms to get off mate
    Cambridgeshire
    I had help from a mate (because he had the tools ) it took us about 1 and half hours to do one side and hour to do the other. The bolts where a bugga to undo but it worked out in the end.
    cambridge
    cheers mate
  1. ARB bush size
    Last Post: 7th April 2012, 15:41
  2. what size ARB bush ? again ..
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2011, 00:09
  3. ARB bush size
    Last Post: 14th November 2011, 22:12
  4. arb bush size??
    By jordib in forum Handling & Braking
    Last Post: 21st April 2010, 10:04
  5. ARB bush size?
    By damian s in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 17:10
