Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: Wynns EGR3
    Regular Member MattW's Avatar
    Sheffield
    Default Wynns EGR3
    Anyone tried this on their CDTI?
    http://www.wynns.be/product.aspx?nav...3&p=23379&l=EN
    Properties
    • Provides immediate thorough cleaning of air intake system, inlet valves, EGR valve and connecting tube between EGR valve and air intake manifold.
    • Strong power jet spray to support cleaning action.
    • Dissolves gum, lacquer, tar, carbon and deposits.
    • Easy to use, cleaning takes only 5 to 10 minutes, with a minimum necessity to dismantle components.
    • Restores perfect air flow towards the combustion chamber.
    • Provides a regular and stable idle.
    • Restores or maintains the engine performance and fuel consumption.
    • Eliminates and avoids starting problems.
    • Improves accelerating properties.
    • Reduces black exhaust emissions.
    Regular Member phykell's Avatar
    Apr 2008
    Cheshire
    Sounds like snake oil to me. I'll be fitting the new, modified EGR at the weekend hopefully. Other than that, cleaning by the existing unit by hand works really well and I can't see how some sort of spray would achieve anything like the same results. As fas as I can tell, the issue is actually due to corrosion of the solenoid actuator rahter than just simple coking up though I've heard it's the coking up which causes back-pressure to force contaminants into the solenoid housing in turn causing the corrosion so if the spray can sort that out, perhaps it would at least act as a preventative rather than cure.
    What would be nice would be Vauxhall removing all doubt and telling us what the issue is and how to remedy it. Further, they could fix the problem as part of the standard service. It's a manufacturing fault as far as I'm concerned and something that should really be the subject of a recall.
    Nottinghamshire
    I used some Wynns EGR3 on my 85k mile 2.2 DTi. It needed 2 cans as it had never been done before, but I would think that one can will do for a car with lower miles.
    It definitely works because I had a look inside the manifold and EGR afterwards to check - it dissolves the soot in the inlet manifold and this is then sucked into the engine and burned up - you have to hold the revs at 2.5k while you spray it in. Obviously, it's not as good as taking everything to bits and scrubbing them - but it it a lot easier.
    As stated above though, it won't solve the EGR corrosion problems on the CDTi engines, just the soot build-up.
    It's really easy to take the air pipe off the inlet manifold of of the DTi engines - I'm not sure about the CDTi's though.
    Winteringham
    where can you buy it from it might be worth a try
    Sheffield
    Quote Originally Posted by gregc View Post
    http://cgi.ebay.co.uk/air-intake--in...02112003r28970
    I'm really interested, as I've seen how caked up the inlet manifold is on my Vectra, from when I cleaned the EGR and Boost sensor. Would be good if this could remove some of the crap from inside the manifold.
    Nottinghamshire
    Wynn's class it as a 'professional' product so you will need to get it online or from a local motor factor - you can't buy it 'retail'.
    Retford
    Anyone tried this yet? Im thinking of getting some as ive got a new EGR but i think the inlet manifold is gummed up
    Would the experts on the forum recommend this for the cdti 150 sri engine?
    cheers
    chris
    Glasgow
    ive just bought some, sounds good and is worth a try.
    i cleaned my egr but im sure theres more cacked up somewhere!
    will keep you posted.
    Retford
    Hi twaiter, where did u buy it from please? im going to order a couple of cans
    I cant see it on ebay.co.uk now - im sure it was there before
    Glasgow
    Quote Originally Posted by eraser2002 View Post
    hi mate i got it from the ebay link above! its still shows 10 available, ive only ordered 1 can as it works out at £10 per can, and im sure theirs another product cheaper that does the same job but looking forward to trying this!
    Ebay link: http://cgi.ebay.co.uk/air-intake--in...02112003r28970
    Martyn
  1. Wynns Diesel EGR3 Air Intake & EGR System Cleaner
    By Gazz in forum Engine & Drivetrain
    Last Post: 11th October 2012, 07:46
  2. Wynn's EGR3 on a CDTI 150
    Last Post: 23rd September 2011, 19:32
  3. Wynns EGR3 any different from Carb Cleaner?
    By richardn in forum Engine & Drivetrain
    Last Post: 4th June 2010, 19:29
  4. wynns EGR3
    By den2712 in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2010, 13:19
  5. Wynns EGR3 spray - wow!
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2009, 18:29
diesel egr 3 were do i squrt it into
