Results 1 to 10 of 11
Thread: astra 120 engine spec
    Jan 2006
    carlisle
    Default astra 120 engine spec
    this is strange
    thinking about getting a astra sport hatch- 2nd hand
    the 120 cdti are cheapish- the 150 cdti are dear
    The ltd edition 888 astras tuned to 200bhp apparently start off as 16 valve 120 bhp cars- the only difference between the 120 and 150 astras is the engine management apparently
    But when i look at the Vx brochure, and speak to vauxhall, they say the 2 astra engines are different, 120 is 8 valve, 150 is 16 valve, (in other words, same as the vectra)
    Anyone know-wouldnt like to buy a 120 astra and find it was a 8 valve
    South Yorkshire
    The Astra engines are the same as the Vectras as far as I a can read. The 120bhp is an 8 valve engine (denoted by all silver letters on rear of car spelling CDTI) whereas the 150 bhp is a 16 valve engine and significantly more advance (denoted by the CD letters in silver and the Ti letters in red).
    An 8 valve will only reach around 150bhp whereas the 16 valve can exceed 200bhp.
    Hope this helps
    Jan 2006
    carlisle
    Default astra engine spec
    thanx- found out that the astra 120s were 16 v initially, however now they're putting in the 8v engines, same as the vectra 120
    Regular Member The Doc's Avatar
    'Norf Yorks.
    As you say Mike, the Astra engines 120bhp were 16v originally. Then they are now 8v.
    Pop the bonnet, if the oil cap is on the right hand side of the engine block, it is 16v. If it is at the bottom (Front) of the engine block then it is a 8v. Pop off the engine cover and you will see the casting has 1 hump or 2. 1 hump is 8v, 2 humps is 16v.
    Wiltshire
    My 55 plate 120 has a 16V engine, so you can pick them up pretty new. Thurlby/888 are still ordering them from the factory, so maybe they've not gone over to the 8V engine just yet?
    Here's what's under me hood!
    I was under the impression that, initially the 120bhp engine was an 8 valve, but Vx has now made it a 16 valve.
    Wiltshire
    I think it's the other way around, but I've never seen an 8V one yet. Probably because nearly everyone gets the 150!
    I've seen loads of 8 valve Vec C 1.9 CDTi 120's, but only on pre 2005 cars.
    Wiltshire
    It used to be
    Vec 120=8V
    Vec 150=16V
    Astra 120=16V
    Astra 150=16V
    There was a rumour that the Vec 120 would become a 16V, but they went the other way and made the Astra 120 an 8V.
    I see, got yer.
  1. astra let engine turbo wanted
    By happypostie in forum Engine & Drivetrain
    Last Post: 6th October 2010, 20:49
  2. astra vxr or a vectra vxr engine ?
    By turbosiggy in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2010, 09:18
  3. astra vxr engine in my vec yay or nay?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2009, 16:08
  4. Vec C 2.0T & New Astra 2.0T. Same engine?
    By Ghosty621 in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2006, 00:00
  5. Vectra Estate- what spec & engine??
    By oldgit in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2006, 17:55
