Thread: 2.0 DTI (Y20DTH) Crank Pulley Problem
    Walsall
    Default 2.0 DTI (Y20DTH) Crank Pulley Problem
    Hello all,
    I have the common problem of the lower crank pulley splitting (the rubber in the middle splitting and falling off) ... I hope it's the right part I'm talking about! (It's the pulley at the very bottom - part GM 09128177 69)
    I found the below on eBay, which is a different part (all metal).
    I emailed the guy, he said this is the correct part.
    Due to the above, and the part was faulty, it was replaced with this part
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...fvi%3D1&_rdc=1
    My engine is mentioned, but I noticed yesterday that the parts were different depending on when in 2004 the car was made (mine was June 2004).
    Could anybody spread some light on this?
    Is this correct what I have been told?
    Thanks for the help.
    Anthony
    Regular Member brad69bj's Avatar
    Jun 2009
    Leeds
    Crankshaft absorber pulley. I`m sure that it will fit fine. Its the same with the 1.9cdti they started to change from big rubber centre to only a small amount of rubber in the centre. I buy a lot of parts from the same Guys and have never had a wrong part. Recommended.
    Walsall
    Thanks Brad.
    Much appreciated!!
    Walsall
    Hello again,
    I purchased the new parts and have fitted the new pulley ...
    but does anyone have a diagram of how the belt goes on ?
    Have searched over the site but cannot find one.
  1. 2.0DTi Crank Pulley !!
    By Led in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 17:55
  2. Crank Shaft Pulley???
    By Stephen S in forum Engine & Drivetrain
    Last Post: 1st September 2010, 20:27
  3. Crank Pulley Damper
    By KevinC in forum Engine & Drivetrain
    Last Post: 11th January 2008, 20:15
  4. crank pulley
    By andyc#elite in forum General Chat
    Last Post: 18th November 2007, 09:12
vauxhall vectra 2.0 dti crankshaft pulley
zafira 2.0 dti crankshaft pulley
vectra c crankshaft pulley fell off
bottom pulley failiure on zafiria
zafira 2.0 dti crank pulley
2.0dti how to remove crank pulley
zafira dti bottom pulley problems
y20dth crank pulley
dth 2.0 crankshaft pulley
Y20 Dth pulley
Bottom engine pulley vauxhall vectra 2.0 dti 2004
forged crankshaft y20dth
vauxhall y20dth bottom crankshaft pulley
y20dth crankshaft pulley
opel common problem with crank sharft pully
vauxhall y20dth crankshaft pulley failure
vectra c diesel y20dth datenbus problem
vectra c 2.0 dti bottom pulley removal
