Results 1 to 10 of 14
Thread: Auto Button on Climate Control Not Illuminated
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Default Auto Button on Climate Control Not Illuminated
    Hi,
    I've just been to look at a 2006 Vectra 1.9 CDTI Estate to replace our 2006 1.8 Hatchback due to space issues with two babies. However when I took it out I noticed that the light on the "AUTO" button of the climate control doesn't illuminate. Could this be a tell tale fault light i.e if it's not lit it doesn't work or just simply a bulb that blown. I tried the button and it seemed to work ok but didn't really give it chance for the aircon to kick in. Any advice will greatly be appreciated.
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    its easy to test... turn the middel knob up, so it writes eg. 7 in fan speed, press auto if returns to normal as before pressed then it works..
    (if GID says eco then the cooling part of climatecontrol turned off)
    So if it is just the bulb/LED in the switch is it possible to replace?
    Engine : 2.2 Direct
    yes it is.. (havnt tried thou as its very small)
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Quote Originally Posted by tramman View Post
    Very small SMD. Ive just done all mine though with no experience.
    So no indication wouldn't be a sign of a fault/leak with the aircon?
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    Also the temperature has to be set on a number i.e between 16 - 28 for the auto button to work. If temperature is set to lo or hi, auto goes off and speed is controlled by the wheel in the middle manually.
    Jun 2009
    Birmingham
    Hi,
    Hi, I don't know a lot about Vectras, but as you can see from an earlier topic I did some work on fixing the climate control on my Dad's Vectra.
    One of the things I noticed was that the auto button did nothing, nothing on the display and no LED. So I looked in the manual and it says that the auto button is to run the Air-con with the ignition switched off.
    It is for the situation where you've had the air con running but then you turn the engine off for whatever reason but you still want the aircon to run. The LED should then illuminate, and it will display something like "Residual Air-con" on the display.
    Obviously it will not last long though as the compressor is not running.
    Surrey
    Quote Originally Posted by cob1980 View Post
    News to Me,
    Mine just works as an Auto function when The AC is on which in my case is allways. I will have to try with the ignition off when I leave work
    Quote Originally Posted by iainm View Post
    News to Me,
    So does yours light up in normal use?
    I've just been and bought the car as aircon seemed to work ok and comes with a good warranty so if any probs do arise hopefully they'll be sorted pretty quick.
  1. Auto Climate Control
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 20th December 2010, 20:48
  2. F.A.O Anyone with a Design model with semi auto climate control
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 18th December 2010, 12:54
  3. Auto climate control fan speed....
    By johns159 in forum Insignia Chat (READ ONLY)
    Last Post: 19th November 2010, 12:58
  4. Auto button next to fan control (bulb)
    By petrolhead55 in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 23:17
  5. dodgy main push button on climate control?
    By effone in forum Electrical & ICE (including SatNav)
    Last Post: 18th June 2008, 08:53
vectra c climate auto button
vectra c climate control auto mode
how 2 fix vectra c climate control
vectra climate control auto button no light
vectra c automatic climate control self test
Vectra c climate control auto light not coming on
where is the on off button on a insignia climate control on off button
the click button on the heater.control
