Results 1 to 3 of 3
Thread: Help please
    leeds
    Default Help please
    I had a fault a few weeks back which was a misfire on cylinder 1, i replaced all 4 of the sparkplugs and the coilpack which fixed the problem and the veccy was running great.
    This weekend i was going along the mortorway at 80 when all of a sudden i felt the car misfire and go into limp mode, i took the car to my local garage who hooked it up onto the tech 2 and got 2 codes for misfires on cylinder 1 & 4. The guy at the garage thought it was the coilpack so i took the coilpack back to hwere i bought it and swapped it for another seen as it had only been going for 2 weeks .
    Put another new coil pack in and the the car was still running like it was in limp mode, hooked it back up to tech 2 and no stored codes so while hooked up to tech 2 i revved engine up to 4500 rpm where it then began to fall and engine light came on and same fault codes for misfire on cylinder 1 & 4 reoccured.
    Im not sure where to go with this now as i have the same fault codes on 2 different coil packs, any suggestions please?
    leeds
    UPDATE: The garage has confirmed that i need a new catalytic converter has it has pretty much disintergrated and was causing the large loss in power and misfires.
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    well atleast you no what it is mate my addvice is a decat now cats a very expensive mate
