Thread: Do brake discs have wear indicators?
    Feb 2006
    Guttedsville
    Question Do brake discs have wear indicators?
    If so, Where are they?
    Brake discs DONT but brake pads DO !!!!!!! Small wire coming from centre of brake pad !!HTH
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    A dent in the front of the car?
    Feb 2006
    Guttedsville
    HO HO HO!!!! At least you didn't say it's printed on the airbag!!!
    How do we know when to replace them is what I'm getting at!!
    Regular Member thewww2's Avatar
    London
    vented discs sometimes have a little step on the outside edge which gives a flat point on the edge when its worn down quite badly. hard to explain i will try to get a pic to show you.
    Feb 2006
    Guttedsville
    Quote Originally Posted by thewww2
    I thought I'd heard that somewhere! Yippee I'm not going mad!
    Admin plasma's Avatar
    On the Forum
    327 Post(s)
    Engine : 150
    Mileage : 74000
    what he means is the disc wears and gets thinner and thinner. But a lip forms around the outside edge of the disc. a way to tell is to run yer finger nail from the centre to the outside. U will feel a lip on the outer edge. the bigger the lip the more worn it is.
    HTH
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    I read somewhere that its best to change the discs every third pad change as a general rule
    N.Wales
    not all pads have wear indicators...
    you may find that even if it was standard on the car, that whoever last replaced them didn't have the ones with indicators fitted etc etc.
    as for changing discs - you will be able to tell when they are on the way out.
    you just know... it's strange but you just feel they're going.
    one thing you can do is each time you get your pads changed, just get the mechanic to check your discs, they will be able to estimate how long they will last.
    dunno about brake discs but dont vectras have a front brake pad wear warning indicator light on the dash??
  1. brake wear sensor
    By dazza2393 in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2010, 22:30
  2. Normal For Back Pads & Discs To Wear Before Fronts
    By Geordieman in forum Vectra C / Signum Troubleshooting
    Last Post: 12th April 2010, 18:04
  3. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  4. Do rear pads have wear indicators?
    By bandrew in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2009, 22:06
  5. Vented rear discs - wear limit
    By Phil in forum Suspension, Wheels & Brakes
    Last Post: 3rd December 2008, 14:20
