Thread: After fitting a new EGR valve revs still drop to low & engine stalls?? Any Ideas??
    Jul 2009
    Lancashire
    Default After fitting a new EGR valve revs still drop to low & engine stalls?? Any Ideas??
    Hi, Im new to your site and am currently at a loss over an issue with my 2.2 Petrol SRI Vectra C, it has a anoying issue that while you are driving you can come to a junction and dip the clutch, the revs drop below 500rpm and the engine stalls? I have fitted a brand new EGR valve and although this car is better it is still soing the same issue. Sometimes is if dont stall it will run very lumpy for a couple of seconds and then be ok. We are really struggling on this one car anyone shed some light for us, thanks Paul & Kat
    Admin plasma's Avatar
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    Throttle body needs a cleanout..? Idle stepper motor?... Pressure regulator??
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    As Plasma said, a dirty throttle body on the z22se is the most common reason for poor idle. This is a new Tb, as you can see the butterfly doesn't seal the hole. Its that tiny little gap that controls the idle, if that gets dirty then you choke the engine, stalling and lumpy idle are always the outcome.
    If that fails to solve it try the o2 sensor.
    south wales
    i will never buy a 2.2 again i know my could be unlucky but my 2.0t perfect this has seemed like a time bomb from when i got it and sounded like it with that chain
  1. 1.8 Petrol Revs Drop Engine Cuts Out
    By vads in forum Engine & Drivetrain
    Last Post: 17th April 2012, 08:23
  2. Revs slow to drop
    By bazsignum in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2009, 07:59
  3. 2.2DTI - Revs drop and engine cuts out
    By altheman2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th November 2008, 20:55
why does my z22se engine run lumpy then stall
vauxhall zafira engine struggling then stalling
egr valve vectra stalling
vauxhall zafira dropping revs and stalling
zafira still revving after changing egr valve
