Results 1 to 10 of 13
Thread: Clutch Change?
    Regular Member storey_3000's Avatar
    May 2006
    somerset
    Default Clutch Change?
    My dti has got a squeak whilst idling in neutral with the clutch pedal released. It stops when i press the clutch and select a gear. I've had it looked/listened to at by my local garage and they think its the thrust bearing. I got a quote from vx for a new clutch, at £432. Will a clutch change replace the thrust bearing or just the plates? (i've never had a clutch change before and my knowlege of clutches is limited) My local garage also mentioned they think the thrust bearing and the cylinder are the same unit, is this acurate? I've a Y20DTH and an F23 box if this helps.
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Quote Originally Posted by storey_3000
    This sounds steep. I have had squeaks with the pedal action before and caused no problems over the years. If the clutch is working fine then I would leave it for now. You can always check the operation by sticking it in say 2 gear put the hand brake on and let out the clutch slowly. It should stall the engine, basic as it seems it will let you know if the clutch is ready to go. Try it and check this for your self.
    May 2006
    somerset
    thanks kc, tried the 2nd gear thing and it stalled fine! its only done 48k so the clutch should be ok i guess. Its just that damn squeaking, its defo coming from the clutch area!
    Regular Member Ian's Avatar
    York
    if your thrust bearig goes, it may well prevent you from changing gear. On older vauxes (sorry I dont know anything about the new boxes) you could remove the clutch and thrust bearing wihin an hour. The thrust bearing sits between the arm that moves with the clutch pedal and the clutch. it allows the clutch to keep spinning whilst seperated (clutch pedal down). If this stops working then I would think that disengaging the clutch would be very difficult.
    May 2006
    somerset
    Think you're right there ian, vx think its more likely the release bearing (I'll have to take their word for it) BTW, a thrust bearing is £111!!! just for the bearing! But hopefully its the release bearing, included in the price! I was actually very surprised to find that vw were the cheapest of all the quotes i got for a clutch change! Almost happy with that!
    The £111 for the release bearing is steep but it's not a usual style bearing unit.. it's a hydraulic unit mounted into the clutch housing. think more small hydraulic cylinder than a ball bearing race.. Gone are the days of the easy change clutches..now it's gearbox off( or to the side ) to gain access..
    They should replace this unit as part of a clutch change, it's stupid not to whilst the gearbox is off..Just check what you get for your money..
    May 2006
    somerset
    yeh. thanks guys, been researching prics and stuff. gonna cost any which way!!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    GSi 3.2 is right
    I had to do it on my last Vec B. The subframe has to come off, gearbox out and then change the release bearing / slave cylinder unit mounted on the inside of the gearbox bell house. Takes quite a long time, so can believe the quote you got, still a lot though. The price for the unit is about right (£110 ish)
    Nicking Ya Dinner.
    I'd try oiling the spring on the back of the pedal, and if that dont cure it, I'd live with it, annoying i know, but you could spend and get it back with something else not right on it.
    May 2006
    somerset
    Booked in with vx for thursday, they are gonna sort it. Its def in the clutch housing, not the pedal and its started doing it at about 30mph. Oh well, once its sorted its sorted (in theory! ) Wish i could be more like these people who can just ignore it or turn the radio up! I'd save loads!
  1. Dmf and clutch change
    By Signum150 in forum Engine & Drivetrain
    Last Post: 5th March 2012, 22:04
  2. Can I change DMF and not the clutch
    By marky2027 in forum Engine & Drivetrain
    Last Post: 12th February 2012, 19:47
  3. change clutch as well
    By marko1973 in forum Engine & Drivetrain
    Last Post: 3rd January 2011, 23:46
  4. how do i change clutch on 2.0l dti
    By kez in forum Engine & Drivetrain
    Last Post: 20th May 2010, 19:51
  5. clutch fluid change
    By nikroc in forum Engine & Drivetrain
    Last Post: 16th November 2009, 23:44
