Thread: Rear Brake Questions
    Jul 2009
    Leeds
    Default Rear Brake Questions
    Hi I am a newbie on ere. It was recomemended to me by a mate to try you guys for some assistance. I drive a 07 SRI 1.8 Vectra.
    Today i have noticed a grating noise at the back end under braking. I am assuming its the pads that are low. I have tried to have a look but the locking wheel nut doesnt want to come off with the basic wheel wrench and its started to round so i am gonna call into a garage and have it removed with a gun.
    The questions i have is
    1, I have only done 27k is that about right for the life expectancy.
    2, Does anyone have an idea how much the replacement pads should cost fitted or supply
    3, Is it likely that i will need the discs replacing even at such an early time in the cars life.
    And finally i may have to use the car this week before i get chance to sort this, will it cause me any major problems.
    Thanks in advance for your help people
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Hi mate, welcome to the site. The rears tend to go before the fronts, and its the inner rear pad that always tends to go first. At 27k i'd say yes, some rears do tend to go at that mileage, but others have been on till 60k. Good rear pads should cost you about £20. You wont need rear disks unless you drive on them too much with duff pads. Try Autovaux in Wakefield for your pads. HTH
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    First of all welcome to the site...
    I believe Vectra is harder on the rears than the fronts. Saying that my car has done 44000miles and I've never changed them.
    To "push" in the rear caliper you need a brake rewind tool. If you "price" this item before phoning around for a quote then you will be in a better position to make a decision.
    I was told that my front discs were wearing but the pads have about 5mm left in them. Strange that the pad material is harder than metal.
    Have a look at the HOW2's as they show you how to remove both pads and discs. If you have the right tools (7mm allen key, brake rewind tool and a torx bit) then its a straight forward job. If you don't have these tools then maybe a garage is a better option. There is no harm in taking off the wheel and having a look....
    Jul 2009
    Leeds
    Quote Originally Posted by John35 View Post
    Cheers for your replys. Since i posted i spoke to an uncle in the trade and got some further answers. I have decided due to the fact i might get the job done cheaply that i will take it to the garage. The discs are fine and i wont be doing too many miles in it till the pads get replaced.
    I did try to take the wheel off as it looks like the outer pad has plenty left on it so its likely as you say to be the inner pad. I am having a problem using my original wheel wrench with my locking wheel nut and its started to round so before its completely goosed i will get the garage to get the wheels off and sort them out
    I did have a browse earlier though and saw the how2 guides and had i the tools i would have had a go. I also have an astra mk5 thats gonna need front pads soon so i might have a crack with that one.
    On another note this site might have saved me some wedge anyways as i am due for 2 new front tyres on the vectra and reading various posts on ere i have found out about using 225/45/17 instead of whats fitted 215/50/17. Looks like a no brainer now so thanks again you lot.
  1. Gsi brake discs/pads questions.
    By big rich in forum Engine & Drivetrain
    Last Post: 9th October 2011, 18:14
  2. Brake Questions
    By Colin_GSi in forum Handling & Braking
    Last Post: 21st November 2010, 12:20
  3. brake questions
    By Big Knox in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2010, 21:14
  4. Few questions about brake discs and pads on a 1.8LS
    By mickydoos in forum Handling & Braking
    Last Post: 26th September 2009, 00:07
  5. Questions about brake upgrade
    By baard in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2009, 17:34
