Results 1 to 10 of 15
Thread: very lucky escape with tyres
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Default very lucky escape with tyres
    I pleased to be sitting hear writing this message, after looking at the state of the tyre I have been running around with (which has included motorway driving).
    I got a puncture yesterday, pumped it up with the small compressor I had in the car and drove home. Checked it periodically on the way and it seemed to be OK. Moved the car fwd in steps to see if I could see anything stuck in the tread, nothing visible.
    Plan was to go this afternoon and get the puncture repaired. Tread is near the wear indicator but thought I could get a few more weeks out of it.
    Just back from Kwik-Fit and it was not until the wheel was off that it became clear how bl@@dy lucky I have been. The inside edge of the tyre is worn and there are 4 areas, each about 10 inches long, where the tread has split from the tyre.
    The Kwik-Fit guy said he is seeing this a lot with performance cars where the faster you go it wears more on the inside (due to the geometry of the suspension) – sounded plausible but I’m sure a knowledgeable person on hear can confirm or deny.
    Anyway, not finishing there, on closer inspection of the springs, both are broken. I have seen what happens when they break – I have been told that one side (I think it is the drivers side) can slip off and go into the tyre.
    Would damaged spring result in excess wear on the very inside of the tyre? I got the car serviced a month ago, I recon the garage missed the broken springs – or is wear like this possible in say 4 weeks if both springs broke not long after the service.
    Anyway , posted FYI, would recommend you give the inside of your tyres a check. This not a budget tyre…… PZero
    Forgot to say,the other tyre is the same (worn on the inside) but it had not split yet. Got two nice shinny Dunlops now, but can't drive until the springs are done.
    Glasgow
    I would contact pirreli that does'nt look right at all!
    Jul 2006
    greenock
    Quote Originally Posted by byebyeitsagsi View Post
    I'm surprised to, but would two knackerd springs do that?
    Glasgow
    If the car was sitting very low then it could have.
    Jul 2006
    greenock
    Was not sitting noticably lower at the front. Just looked at it again outside and it looks normal.
    Regular Member neilybhoy1888's Avatar
    caithness
    pirellis dont have the hardest of sidewalls the broken springs may have cauzed this but it would be well worth while getting the 4wheel alignment checked just incase i have seen this a few times in ma tyre fitting days and days as a storeman and it has nearly alway been due to poor inflation or wheel alignment etc
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I had a problem where the nearside tyre is wearing on the inside alot quicker than the outside because of a dodgy ball joint in the tracking.
    Gazza4
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    very lucky indeed mate just think what would have happened if that had blown at motorway speeds i'll be checking my tyres more frequently now
    Regular Member ballan22direct's Avatar
    isle of lewis
    i had a similar problem with my old motor. both front tyres were like this. only when i took the wheels off for a clean i seen it.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sorry mate but i didn't notice you saying if it the front or rear
  1. Lucky Escape
    By kon123 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2009, 09:25
  2. Lucky escape.
    By MalcGSI in forum The 'Off Topic' room
    Last Post: 6th March 2009, 21:15
  3. a very lucky escape
    By solorider in forum General Chat
    Last Post: 18th January 2009, 12:36
  4. A Lucky Escape
    By mickeyc in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2007, 16:41
  5. Lucky escape!
    By SignumPhil in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2006, 14:55
