Results 1 to 10 of 14
Thread: exhaust fumes
    Regular Member chinky's Avatar
    midlands
    Default exhaust fumes
    I'm getting exhaust fumes through the vents and can smell them in the engine bay . any ideas anyone.
    Regular Member Marc Hutton's Avatar
    Edinburgh/Catterick
    A hole in exhaust or leaking manifold maybe.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    yes i can tell you prob 100%, you mostly get this at stand still,at start up, and when you stop/start, if so unfortunately your swirl flap inlet manifold is shot!, fumes are passing the part you can see moving when revved up, take your engine cover off and look to the top rear and look at the oily gunged area!! your rod may be in place and working but the fumes pass and get sucked in through the heater, a good test is to press your recirc button and run around with it like that and if you get no smell it will most likely be that and you will either have to get it done or like i do press the button as and when.
    midlands
    is this common at only 27000 miles
    midlands
    and is it an expensive repair
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    at low mileage, no i dont think so, have a look at your manifold its a two minuite job, come back and give feed back as to how it is!
    vauxhall charge £500 manifold replacement only,
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Quote Originally Posted by Marc Hutton View Post
    This is what I had on a Citroen ZX of mine, albeit at about 70000 ml, not 27,000!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    it does sound unusuall i would have thought at 27k, could be fumes from egr gasket or simular, wouldnt have thought exhaust at that mileage.have you looked yet??
    midlands
    is this my problem
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    just a little further backwards/towards the windscreen you will see a bar connected to four round discs.
    http://www.vectra-c.com/forum/showth...840#post859840
    try looking here, a nice new shiny one!!
  1. smell of exhaust fumes
    By murfcitygent in forum Engine & Drivetrain
    Last Post: 18th October 2016, 18:59
  2. exhaust fumes in cabin
    By chrislloydie in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2013, 07:33
  3. exhaust fumes in car
    By wally10 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 13:46
  4. Exhaust fumes in cabin
    By Nicolas in forum Engine & Drivetrain
    Last Post: 18th January 2011, 08:18
  5. Engine/exhaust fumes in me car!
    By VXR CDTi in forum Engine & Drivetrain
    Last Post: 22nd February 2009, 23:02
