Thread: permanent live to cig lighters
    lincolnshire
    confused permanent live to cig lighters
    Hi guy's first post so be gentle with me.
    Is there any way to make a permanent live to cig lighters as I have to use my laptop in the car and I do not like to leave my ignition on without the engine running.
    I am sure it is just a matter of rewiring the fuse but I would appreciate some ideas on this. Thanks
    Regular Member 98vectra's Avatar
    stoke on trent
    Yes this bugs me too and the strange thing is my dads Astra H sri has permanent live cig lighter.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    you can take a perm.live from the boot and run it up.. ive done that for ciglighter in the boot and dvd-headrests...
    11 Post(s)
    Quote Originally Posted by 98vectra View Post
    You'll probably find that it automatically shuts off after approx 20 mins. There is mention of it somewhere in the handbook.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    You could just run a live feed from the battery red terminal) and a chassis ground to the cigar socket...just disconnect the existing plug and tape it out of the way.
    Don't forget to put an in-line fuse in the live feed rated at 15 amps (blue fuse) I think
    Simples!!!
    stoke on trent
    I never knew that, I suppose thats enought time if you are running a sat nav and nipping out to pay for fuel .ect.
    Engine : 2.2 Direct
    mine turns off straight away.. no delay..
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    if you do this, mamke sure that you put the fuse as close to the battery as you can. That way, the fuse will blow if you trap the wire somewhere and it cuts through, otherwise your liable to set the cable and thus the car on fire!
    [Ex]Admin Duncan's Avatar
    I made my front and rear sockets permanent live by running a cable from the front fuse box to each socket.....
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    mine turns of straight away 2 no delay
  1. permanent 12v live
    By rockafella8587 in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2012, 17:53
  2. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  3. Permanent live in boot
    By montyfert in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 20:11
  4. Permanent Live in Boot?
    By bandrew in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2009, 15:03
  5. permanent live
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2008, 16:25
