Results 1 to 10 of 17
Thread: reverting back to oem headunit cdc40?
    Carnoustie
    Default reverting back to oem headunit cdc40?
    Ok when I bought my vec it had already been single din converted, I fitted my Blaupunkt Memphis usb mp3 but have bought a cdc40 opera and screen, as I never removed the factory unit what bits will I need to fit the cdc40 in? I know I will need a cage, anyone got one laying about? what else might I need?
    Also will be selling the Blaupunkt just over a year old, cracking unit, still 11 months warranty on it.
    http://www.bluespot.co.uk/stock/memphis.asp
    cheers Ronnie
    Carnoustie
    bump
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    There are various links on here to go the other way...fit an after-market head unit in place of the original...however you will probably need: -
    1) Double din cage
    2) DAB unit...unlikely that yours came with one unless it originally left the factory with a cd40 fitted.
    3)DAB link loom (I think...may already be located at the rear of the glove-box where some DAB units were mounted)
    4) Remove Blaupunkt radio and it's conversion lead...also how old is your car?? Pre 2004 cars have ISO radio plugs, whereas the later radios / cars (2004 onward including the cd40) use a connector called a fakra quadlock.
    5) Ask your expensive dealer to Tech 2 all 3 items into the car (screen, cd40 and DAB unit)...approx £60 + vat.
    Hope that helps!!
    Carnoustie
    Quote Originally Posted by Robsey View Post
    1) Double din cage
    Hope that helps!!
    Thanks Robsey, its 2004 full can, I think it had a cdc30 before, so no dab unit! unless I can find one on ebay, I thought if the screen and headunit were paired would not need tech?
    cheers Ronnie
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    You are correct, but wherever you got the screen and head-unit, you will also need the dab unit....yours is a three way marriage.
    They will all need to have come from the same vehicle...with the same radio pass code!!
    However....I have been able to work the wrong screen on my head unit...(cd30 and cd70) as long as they were not in delivery / safe mode.
    If they are in safe mode, then the radio will ping at you every five seconds.
    Carnoustie
    Thanks again Robsey, have emailed the seller as I think he still has the car, do all cdc40 have dab units, I think his is a 2007 model
    cheers Ronnie
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    As far as I am aware, yes they do
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Presumably you can just fit the cdc40 and make do with FM - unless you specifically want digital radio.
    Carnoustie
    Quote Originally Posted by vxvirgin View Post
    yes that true, our other car has dab and I like it but can't have it all ways I guess, next worry is will it play mp3 as its uknown till I fit it!
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Not totally definate about this, but I think it is only the basic cd30 that does't play mp3's...
    For those that will question me there is a cd30 mp3 version aswell.
  1. CDC40 to CDC40 MP3 upgrade.... any advice?
    By eamond in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2012, 08:02
  2. Replies: 0
    Last Post: 5th July 2012, 23:27
  3. reverting back to longer Air Intake
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2009, 17:55
  4. has the CDC40 opera dab headunit got a AUX/PRE input?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2008, 20:22
  5. Reverting back to cd30
    By scott_150cdtisri in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2006, 11:18
