Thread: Starting - engine juddering
    Jul 2009
    oopnorth
    Exclamation Starting - engine juddering
    Hi,
    It's my 2003 2.2 sri - all seems well when driving but a couple of times recently the engine has been juddering when starting from cold / at idle [best description i can give]. It sounds like when a coilpack went on my 1.8T leon cupra r a few years ago, but that was when driving, this is stationary idling cold start. Didn't happen today ?
    Could it be an emissions sensor ?
    P.S. Newbie, please be gentle if this is a well versed topic, i did search first though.
    Jul 2009
    oopnorth
    Anyone ?
    Apr 2008
    BEDFORDSHIRE
    Angry
    Quote Originally Posted by GWHIZZER View Post
    Hi,
    HI I have exactly the same model and the same problem and I have replaced the coil pack and still no joy. Getting really fed up with this car thinking of getting rid of it. Let me know if you find out what it is.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Could be anything from a dirty throttle body to DMF. Are the revs fine?
    Jul 2009
    oopnorth
    Sorry for delay, been away.
    Yes for me the revs are fine, and after 20 seconds or so it has cleared the juddering/rocking motion - it is like it is struggling to get the right mix of air/fuel/timing
    Strangely it hasn't done it the last 4 starts ?
    Vehicle : SRi
    Mileage : 137000
    Any sort of noise at all?
    Apr 2008
    BEDFORDSHIRE
    Mine makes a mis-firing sound but clears after about 20 seconds
    Jul 2009
    oopnorth
    Quote Originally Posted by LEEPOLLARD View Post
    same here, with the engine juddering at same time - i guess this is to be expected if misfiring.
    It's going to get all fluids and filters done, and EGR cleaned - see how that helps.
    Glasgow
    guys i recently had the same issue with you 2, its like a judder/knocking noise? only last afew seconds then all is well untill you start it again?
    If Yes then i recently changed my injector 3 wiring and it no longer does it. dont know how this applies to your selfs but a possability!
    good luck
  1. Replies: 5
    Last Post: 25th January 2013, 17:44
  2. Engine fault light on / Juddering when hot
    By Angelchops in forum Engine & Drivetrain
    Last Post: 17th September 2011, 19:16
  3. Engine Juddering and struggled to reach 70 mph
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2009, 23:17
  4. Engine Problems again Spanner and juddering !
    By CdRsKuLL in forum Engine & Drivetrain
    Last Post: 6th December 2007, 22:27
  5. Engine not starting
    By NI-2.2SRI in forum Engine & Drivetrain
    Last Post: 29th April 2007, 13:46
