Thread: Removing rear wiper arm??
    May 2008
    Derbyshire (south)
    Default Removing rear wiper arm??
    Hey folk, a little help please??
    I want to swap my rear wiper arm on my Vec hatchback to the flat blade type.
    I have the flat one to put on but i have a problem. Undone the nut that holds it down but it still won't budge, i have applied as much pressure as possible, as i don't want to end up smashing/cracking the glass.
    Have i missed something, is there another locking ring somewhere as i have tried levering it off, pulling at it, tapping all round But its as stubburn as crash gordon & won't budge.
    Any help/advice would be appreciated
    Regular Member poves's Avatar
    lancashire
    spray some wd40 or oil onto the spline , let it soak for a few mins , then lift the wiper arm vertical and hold the bottom near the nut and wiggle it , also a few light taps about 6 inches from the nut housing on the wiper arm may loosen it.
    If not you will need to get a wiper pulling tool , about a tenner I think.
    May 2008
    Derbyshire (south)
    cheers mate i will try again tomorrow, i had given up getting this off, as i know my luck, i'd bust the screen, knowing my strength
    I wasn't sure bout wd40 as i wasn't sure if it'd react on the paint??
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    May 2008
    Derbyshire (south)
    Thanks for the link John!!
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    i had to use something similar to john.robertson2 link to get mine off, wouldnt budge, and didnt want to force it too much cus of glass.
    the tool just popped it off in a few seconds.
    May 2008
    Tyneside
    These are much better pullers, the ones shown in the link above just bend.
    http://cgi.ebay.co.uk/HEAVY-DUTY-WIP...3A1%7C294%3A50
    i used a big ball joint puller on mine, something i had in the garage. bit big for the job but just fit under the arm so worked a treat.
    May 2008
    Derbyshire (south)
    Quote Originally Posted by tridley View Post
    Thanks for the link mate!
    I still haven't done it as i got called into work, I may have a ball joint puller so i shall find it out & have a look. i shall use penetrating oil to see if this will ease it, but it sounds like everyone has struggled to get these off.
  1. Removing wiper arms
    By sjanisz in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2010, 16:21
  2. Replies: 11
    Last Post: 3rd December 2009, 14:21
  3. Fitted rear spoiler, rear wiper arm hits it
    By JuzzyD in forum Bodywork & Interior
    Last Post: 9th September 2007, 19:00
  4. Removing rear wiper??
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2007, 19:09
  5. Removing wiper arms?
    By jamesr in forum Bodywork & Interior
    Last Post: 1st March 2007, 12:00
corsa rear wiper arm removal
vectra rear wiper delete glass look
