Results 1 to 10 of 15
Thread: Newbie in need of help, PLEEEEEASE.
    New Member gavinthetazman's Avatar
    Jun 2009
    cumbria
    confused Newbie in need of help, PLEEEEEASE.
    Hi All, Im having trouble with my 52reg 1.8 16v Vectra club, my eml light keeps coming on and the code says P0170 and it also revs erratically when idle.
    I have a u480 hand held code reader and the code means: fuel trim malfunction bank 1. I have replaced the following to try and rectify the fault: Air flow meter, both lambda sensors, coil pack (as advised by garage who had the car for 2 weeks). I had the ECU tested by ECUtesting.com and they found no faults with it.
    I have removed and cleaned the throttle body, rocker cover, and breather hoses and added some injector cleaner to the fuel to clean them out. The car seems to be more responsive after all this but it still idles irratically and the eml light came back on stating the same code.
    PLEASE CAN ANYBODY THROW ANY LIGHT ON WHAT TO TRY NEXT, AS MY BANK BALANCE IS DWINDELING FAST.
    Gavin.
    Jun 2009
    cumbria
    Somebody pleeeease help im desperate and dont really wont to take it the stealers. Help pleeease.
    Regular Member paul.sessions's Avatar
    leighton buzzard
    have you tried cleaning the egr valve??
    Administrator plasma's Avatar
    On the Forum
    400 Post(s)
    Engine : 150
    Mileage : 74000
    is the Airflow meter around the correct way??? check the direction of the airflow on the unit (theres an arrow on it)... this could cause that problem
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    A quick Google brings up loads of faults mate, from blockage in the intake, to engine temp reading wrong, causing the fueling to increase.
    Regular Member Vectra Dan's Avatar
    Jun 2009
    winsford
    hi mate i just bin on my autodata and i found the error code which u have a problem with. This is what my autodata came up with buddy
    Jun 2009
    winsford
    let me know whether that help u or if there anythin else i can do for ya mate
    btw is it a vectra b or c
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by Vectra Dan View Post
    A 52 plate Vec C will have the Z18XE engine anyway as would the B.
    Jun 2009
    cumbria
    PLASMA: The airflow meter is fitted in the correct direction.
    RUSHY: I have been told about the temp switch but as far as I can tell it works ok (reads around 90 when warm), should I change it as a matter of precausion as its not to expensive to buy?
    VECTRADAN: I have autodata myself and have tried and tested all the components listed but still has the fault, which is why I have no idea what else could be causing the fault, other than changing the temp switch. Its a Vectra C by the way.
    Thanks everyone for your help and advice, I will keep this post updated to let you all know how I get on.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by gavinthetazman View Post
    Mate do me a favour Andys done the same thing and we unplugged the MAF and hey presto it worked fine we just give it a clean and so far no problems.
    Just unplug the cable from the maf and see if it goes back to normal let me know
  1. newbie asking newbie question :-)
    By gavatron in forum Engine & Drivetrain
    Last Post: 6th February 2012, 10:39
  2. Newbie
    By bigjjfaetheyy in forum Introduce yourself.
    Last Post: 2nd October 2009, 08:57
  3. Newbie.
    By Martinlw in forum Introduce yourself.
    Last Post: 1st October 2009, 05:46
  4. Newbie
    By VectraAlan1888 in forum Introduce yourself.
    Last Post: 16th September 2009, 19:02
  5. newbie.
    By signum@37 in forum Introduce yourself.
    Last Post: 3rd August 2009, 12:25
