Thread: oil change check, flush???
    grimsby lincolnshire
    Default oil change check, flush???
    high i am going to be doing my own oil change and filter change on sunday and i was wondering weather it is worth doing an engine flush i have read some threads about it and they say not to if it has alot of miles on it and my car does 96k but it has a full service history so will it be fine any help will be great thanks
    Matt
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    If its never been flushed before then don't bother. It may cause more trouble than its worth.
    Good clean oil is all an engine really needs....
    Regular Member xrken's Avatar
    northampton
    rolleyes
    i change my oil every 10k and i think you should flush it every change
    Regular Member Vectra Dan's Avatar
    Jun 2009
    winsford
    Don't bother with the flush just drain the old oil and replace it with good qaulity oil. thats all it needs pal
  1. Valve Clearance check with Cambelt change
    By LeeU in forum Y & Z30DT Specific
    Last Post: 6th April 2012, 00:51
  2. Oil & filter change.do i use an engine flush.
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 21:51
  3. Flush or No Flush(2.2Dti)
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 20:35
