Results 1 to 10 of 16
Thread: help needed from IT pros
    Edinburgh
    Default help needed from IT pros
    Any of the IT folks on here had any experience of McAfee Safeboot/Endpoint Encryption?
    Nottinghamshire
    We use it at work but it is installed on my PC remotely, so it depends what the question is.
    There's information about support at the bottom of the page below.
    http://www.mcafee.com/us/about/corpo...html#technical
    Edinburgh
    well basically my works laptop is encrypted with this product. Yesterday apparently there was some issues and after I reboot my laptop I now get a message saying "hal.dll is missing or corrupt". (won't even boot into safemode)
    Now being an IT pro myself I'd normally have a good chance of fixing it however because of this stupid encryption, I'm wondering if I boot to the XP recovery console, will it still be able to read my hard disk with it being it the correct laptop?
    Regular Member fingers66's Avatar
    Carpe Diem
    Heres how to restore hal.dll from XP cd ............. easy enough to do
    Edinburgh
    yes, I know how to restore the file but if the XP recovery console can't read my hard disk then I'm stuffed.
    I need to wait on my wife bringing home a CDROM for my laptop (currently occupied with a media bay battery) before I can attempt it. Just wondered if anyone on here knew if the drive would be readable because it's in the correct laptop or if it wouldn't be readable because I haven't booted from the hard disk and therefore potentially not loaded safeboot
    Surrey
    You should be able to get a Macafee endpoint recoverydisk. It is basically a PE disk with recovery software. We tested this product and rejected it in favour of another
    Nottinghamshire
    Yes, you will need proper Safeboot recovery software. The very fact that Safeboot encrypts your hard disk means that the only way to recover data from it is via Safeboot's own recovery software.
    A colleague had a similar problem during a Windows service pack installation that left the PC unboot-able.
    Not like the good old (but very insecure) days when you just installed the drive as a second disk on another PC and copied the data off of it...
    Good luck.
    Edinburgh
    got hold of McAfeee SafeTech however you need to get a code of the day from McAfee to authenticate to it and they won't give it too me with my companies "grant number" which I don't have grrrrr and unfortunately my company's internal IT dept is rubbish.
    Nottinghamshire
    Sorry to hear that. Unfortunately, I don't think that there are any back doors in Safeboot (or companies wouldn't buy it to protect their data).
    I think that you may need to keep pestering your IT department into sorting this out for you (surely this is what they do?!) or giving you the code.
    Edinburgh
    that is what they do just slowly, took them about 3 weeks to respond to my last support ticket
  1. EGR pros and cons
    By faz123 in forum Engine & Drivetrain
    Last Post: 7th November 2012, 15:40
  2. Pros and cons of mapping.
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2012, 08:16
  3. 255 or 280. Pros and cons.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 18:59
  4. The pros and cons of another marque.
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 12:39
  5. Should I fit a CR1 - what are the pros + cons
    By ballogie in forum Diesel Engine related
    Last Post: 19th January 2007, 19:57
