Thread: Sri springs on an sxi 1.8?
    haworth
    Default Sri springs on an sxi 1.8?
    Would this be an option? my front spring is broken and i wondered if the sri springs would fit allround as they are lower or to get some 30/35mm lowering kit, any suggestions, thanks
    Regular Member LJ sxi-nav's Avatar
    Winchester
    I have a 2005 SXi and it already comes with the same suspension set-up as the SRi. Not sure if the earlier SXi had the same suspension set-ups as standard.
    i think most on here will recommend an aftermarket kit if you are replacing anyway...
    Sunny Dartmoor
    SRi one's will fit no problem,but if you go for lower than 30 mm then you'll have to change the shocks too,hth.........
    Regular Member al21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    Vehicle : Vectra c
    Engine : 1.9 CDTI 150
    Year : 06
    Mileage : 187000
    Get some Eibach's with a 30mm drop, it'll be cheaper that baying two new springs from vaux
    AL
    haworth
    Mmm, just been looking on LMF and:-
    Spax = £105 + £10 shipping 30mm front & rear
    Apex = £110 + £10 shipping 35mm front & rear {rrp £123= 10%discount}
    Supersport = £105+ £10 shipping 35mm front 30mm rear
    car is on 17ins alloys, why are S/sport different heights front & rear and is this an advantage? HELP PLEASE, the prices are good but what should I choose?
    Sunny Dartmoor
    The veccy and signum ride higher at the front than the back,so yes it would be better,i've fitted 45mm/40mm Pi springs and it now sits nice and level,i'd go for the Pi 30mm lowering springs m8,less than £100 delivered...............
    http://www.pi-suspension.co.uk/p1253964.htm
    haworth
    cheers glen,
    been on the site and i think the 30mm pi`s are the ones, especially with free delivery, its a very good deal thanks for the info m8
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
