Thread: headlight misted up
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default headlight misted up
    I got my 6000k hids fitted at the weekend and all was fine,but today with all wet weather about i have noticed that one of my headlights has misted up.I opened the bonnet for a nosey and i noticed that the guy who fitted them has taken a chunk out of the rubbers protecting the bulbs to let the wires pass through.Does anyone have any ideas how i can prevent the lights misting up in future?
    Regular Member collow123's Avatar
    cumnock ayrshire
    Take the units out and dry them with a hairdryer then once dry silicon the wires where the rubber is cut out to seal it.... Then it should be watertight again mate
    Derry
    I have removed the rubber covers from the back of the lights to let a bit of air in to see if that helps,if it clears itself do you think it would be safe to leave the covers off permanently?
    Derry
    Bump?
    Newcastle under Lyme
    I thought they had solid covers on the headlights and rubber cover on the motor. Oh well you should be ok leaving them off but inevitably it wont get rid of the moisture permanantly. Everytime your lights heat up the moisture will dissapear. If you want rid you need to dry them out and repalce the seal
    Derry
    Thanx for your opinions guys,i will give it a try.
    Aug 2007
    Cumbria
    I had this problem with one of my headlamp units when the rubber cover was not fitted snugly. Hugley misted up. I parked the car - took the rubber cover off - started the engine - switched on the headlamps fully. The 'heat' from the lamps dried out the air in the lamp - took 3 hours of engine idling over. May have cost about £3 in petrol but solved the problem as I could not get a hairdrier near enough to the back of the lamp unit and you have to remove half the car to get the lamp unit out.
    Hope this helps
    Derry
    thank`s m8,i took the rubber cap off and i have kept it off and it has cleared up,all except the part of the light where the indicator is,is there a cover that i can remove to clear this part of the light?
    WGAF#5
    get yourself a little packet of silica gel - similar to the ones you get in new boxed items - remove the cover after you park her up for her overnight rest, and place it inside the light the put the cover back in place - this will absorb the moisture overnight = remember to remove the following morning before driving off because they look really funny flopping around at the bottom of your headlights as you drive round corners !
    and then remember to ensure the seal is water tight otherwise the moisture will return
    Derry
    Thank`s Dez,i`ll give it a try,all i need to do is find one of those little packets first.
  1. misted up headlight
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2012, 22:03
  2. Misted Lights
    Last Post: 30th November 2009, 22:20
  3. Fog light misted up
    By fishphone in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2007, 23:01
  4. Fog light misted up!
    By bertxuk in forum Bodywork & Interior
    Last Post: 10th December 2007, 12:04
  5. Signum headlight misted up.
    By mike56 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd November 2007, 18:30
