Thread: Will these fit?
    Regular Member sri_joe's Avatar
    Accrington
    Default Will these fit?
    does anybody know if this fitment will fit a 07 vec c
    http://cgi.ebay.co.uk/Team-Dynamics-...1|293:1|294:50
    Jun 2009
    northern ireland
    yeah should fit usually vw and vectra same fitment
    Accrington
    cool cheers just needed a second opinion
    Regular Member andy76's Avatar
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    Quote Originally Posted by trev16185 View Post
    so would my sri wheels fit a vw?
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    some of the newer VW's have a PCD of 5x112 which would fit the vec with 'Wobbly bolts', but the centre bore is a lot smaller on VW's (57mm i think) whereas the vecs is 65.1mm so without borin the centre out the wheels wont fit.
    you would need to check the PCD and the bore size of the wheels in the link. Because they are aftermarket wheels they may have a larger centre bore (just needin spigot rings to fit).
    I think the MK5 Golf is 5x112 so that would be fine (using 'Wobbly bolts').
