Thread: how do you overcome a deadlock
    halifax
    Default how do you overcome a deadlock
    on an astra h,07 reg, gotta be same as veccy i think.
    n/s door wont open but motor can be heard
    halifax
    someone must know
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Moved to a better suited section
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    should still be under warrenty take it to a dealer
    halifax
    Quote Originally Posted by neverlandandy View Post
    cant. Cat d write off
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    last time i had to overcome a deadlock i had to drill the lock to bits then get busy with jemmys it ruined the door and the lock striker pin but a used door with its lock is usually less than £100 and labour to release it could mount into the hundreds
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    I did hear once that the AA know how to defeat the deadlocking.....something about getting at the wiring under the front wing or something like that.
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Quote Originally Posted by john_k_sri View Post
    It is very, very easy to overcome the deadlock... Simply remove the door card, locate the deadlock solenoid and wire it to 12v. And DA-DA it opens...
    The only thing is you have to open the door to remove the door card!
    Back to square one...
    Accesing the front wing will get you access to the wiring to the ECU in the door. But not let you open the door via the wiring.
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    When I worked at a car garage we sometimes had this probelm, we just ripped the door card off and fix the problem, then order a new door car as it's cheaper. You should be able to open the door easy enough once the door card is off.
    Regular Member KTM Chris's Avatar
    Nov 2007
    North Lincolnshire
    Don't want to ruffle any feathers here, but wouldn't it be better to answer questions like this by PM once precautions had been taken over the use of the answer?? I'm not for a second suggesting that vxr is up to anything dodgy, but any unscrupulous guest now knows how to get the deadlocks undone for the price of a secondhand doorcard!
  1. Deadlock not spring?
    By Thomza in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2012, 15:58
  2. Help me overcome insomnia
    By kitchpoo in forum General Chat
    Last Post: 27th October 2005, 10:46
  3. Double click/Deadlock
    By Jamie in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2005, 13:24
astra h deadlock
how to remove deadlock on a vectra c
opel deadlock open how to
