Results 1 to 10 of 24
Thread: Help keep getting limp mode? 1.9cdti 150
    Jun 2009
    north east
    Default Help keep getting limp mode? 1.9cdti 150
    Hi all,
    firstly great forum, yes I am new.
    Got limp mode the other day, so here is where i'm at:
    • Cleaned EGR valve & boost sensor-still hapens
    • Took to main dealer- , said it was the exhuast pressure sensor Now 100 quid lighter (3days out of warranty)- drove done the road light came on again!!
    • it clears if you restart the car, but once hot you only get a mile or so.
    car is an 06
    Any help very much apprciated.......
    (its also lumpy on start from cold)
    Jun 2009
    north east
    ok now done the quick fix for a pound using the tap washers, and know the engine managemnet light is on !!! the 3rd sswirl pot thingy felt very stiff if that helps !!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by rocket_man View Post
    I take it by tap washer fix you mean the inlet bar?
    You wont be able to move the 3rd flap as that is the one attached to the motor and that drives the others via the bar?
    I take it the inlet bar had fallen off?
    You may have the bar on too tight now you have the tap washers on the bar and the motor not able to open the flaps - that will give you a constant spanner light...... whats the code?
    Jun 2009
    north east
    the spanner has gone but know the management light has come on, the bar does feel very tight, no movement????
    the inlet bar had not fallen off just very loose and wobbly....
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Had the same issue for the last three weeks m8 and it was found to be a bust intercooler. But.... It was also pointed out that my swirl pot rod had popped off and had allowed the manifold to soot up so I needed a new manifold.
    Gazza4
    Jun 2009
    north east
    hmmmm, even though its just out of warranty isn't this a design fault that vx should rectify reading the forums?
    Middlesex
    Trim : SRI
    Mileage : 100k
    As I say you wont be able to move the bar as the 3rd one is linked to the solonide (motor).
    TBH - if the bar hadnt come off - it was doing its job, so would have left it. the tap washers may be too tight on the swirl tops therefore not allowin the motor to open the swirl flaps..
    When you say EML - do you mean the orange engine symbol - thats actually the emissions light on later cars. Could be where the swirl flaps arnt able to move I guess - but I think that normally throws a spanner light - still possible tho..
    Middlesex
    Trim : SRI
    Mileage : 100k
    Mate - I had to have a new inlet and all at 36K and 7 months over 3 years - VX wouldnt pay a penny and I took it up to VX UK.
    even the dealers said its a pure design issue - but still nothing.. sorry!
    Jun 2009
    north east
    thanks, i will try taking of the tap washers shortly and see what happens, and yes its the orange engine symbol......
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    to confirm they are moving. look at position with engine off. Then start engine and recheck position, they should have moved.
  1. limp mode above 2500rpm Vectra 2006 120bhp 1.9cdti
    By mani911gt3 in forum Engine & Drivetrain
    Last Post: 3rd September 2011, 20:07
  2. 1.9cdti 120 estate eng stutter limp mode
    By blackadder62 in forum Engine & Drivetrain
    Last Post: 7th February 2011, 14:53
  3. 1.9cdti limp mode
    By darko2301 in forum Engine & Drivetrain
    Last Post: 14th May 2010, 08:58
  4. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  5. help limp mode on vectra 1.9cdti
    By signum junkie in forum Vectra C / Signum Troubleshooting
    Last Post: 27th April 2008, 22:38
