Thread: Misfire
    Jul 2009
    Oldham
    Default Misfire
    Recently had my engine changed and got car back 4 days ago
    Yesterday when driving , the EML came on and car slowly ground to a halt.
    Have it diagnosed as
    p0203-04 Cylinder 3 Injector Circuit Open
    p0202-04 Cylinder 2 Injector Circuit Open
    p0203-04 Cylinder 4 Injector Circuit Open
    Strange thing is, 1 hour after fault diagnosed I jsut switched engine on and wohoo it was working... I got the guy to come back and remove errors
    Today after 2 hours of driving, its once again done it again..
    Seems to be when the engine is warm!?!?!?
    Spoke with the lad that has fitted my engine and he told me to replace Coil Pack - got one from scrappy, fitted and still have the same problem.... Any ideas?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Check the plugs on the injectors. I got those fault codes when I unplugged mine on the 3.0
    Jul 2009
    Oldham
    sorry dont get what you mean, check if the plugs in securely?
    There are no leads, its a long coil pack direct to plugs
    its a 53 plate btw
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Thought it was a diesel
    Jul 2009
    Oldham
    z18xe btw
    Bristol
    Vehicle : CDTI 150
    You need to check that the ECU matches the engine fitted, sounds like its getting a bit confused.
    Would be unusual to have 3 broke injectors, next thing back is wiring to the injectors then the ECU.
    Jun 2009
    South West
    Who changed the engine. The injectors on 1.9 engines have to be programed to the ecu to run correctly using tech 2 I think petrol may be the same.
  1. misfire on 1.8
    By Lozza in forum Engine & Drivetrain
    Last Post: 9th August 2012, 23:57
  2. misfire?
    By ivesy in forum Engine & Drivetrain
    Last Post: 11th February 2011, 19:55
  3. V6 misfire?
    By lencuff in forum Engine & Drivetrain
    Last Post: 16th November 2010, 21:10
  4. 1.8 misfire
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 23:09
  5. Misfire
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2006, 16:30
