Thread: Z1.9dt engine
    Regular Member brad69bj's Avatar
    Jun 2009
    Leeds
    Default Z1.9dt engine
    Can anyone help? I have a vectra 1.9 DT with MIL light on and only revving to 3k. The fault code is 1125 Accelerator Pedal Position sensor. I have swapped the pedal for 1 off my other car also a 1.9DT, same numbers etc.. and still the same! I have swapped the airflow meter, egr valve, boost sensor, wastegate solenoid valve, and still the same! My other car runs perfect with all the swapped parts.. Any Ideas?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Swirl valve/rod on the intake manifold maybe?
    EDIT: Just had a quick google and found another thread from here and it mentions that there are 5 sub codes to the one you gave which are:-
    P1125-1 Throttle Actuator Malfunction
    P1125-2 Throttle Actuator Supply Low Voltage
    P1125-3 Throttle Actuator Feedback Circuit Malfunction
    P1125-4 Throttle Actuator Feedback Signal Range/Performance
    P1125-5 Throttle Actuator Feedback Powerstage High Temperature
    The guy fixed his with a new throttle body. HTH
    Jun 2009
    Leeds
    Thanks mate, I was just thinking of trying the throttle body next. I kinda got to thinking that maybe it`s the receiving end of the throttle if you get what I mean.
    Vehicle : SRi
    Mileage : 137000
    No probs
    Jun 2009
    Leeds
    Sorted it. Turned out to be the throttle body. When I took it apart and looked inside there are 2 gearwheels, the small 1 had a tooth broken so when it got to that point it wouldnt open the butterfly any further.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by brad69bj View Post
    nice result m8
    Vehicle : SRi
    Mileage : 137000
    Nice one mate, glad you got it sorted. Where abouts in Leeds are you from?
    Jun 2009
    Leeds
    Hi, I`m in Oakwood near McDonalds. I have a fleet of Vectra cdti 8 valves [Taxis]. How about you?
    Vehicle : SRi
    Mileage : 137000
    Down in Bramley mate.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
